- 24,488
- 15,064
You have to make the qulification that you interpret the vector space as an affine space in the above explained way. Otherwise it's not understandable, at least not for one trained in the German mathematical tradition.
Dale said:"An affine space is like a vector space that has forgotten its origin. "
Dale said:"When considered as a point, the zero vector is called the origin "
Dale said:"the point corresponding to the zero vector (0), called the origin"
Dale said:"An affine space or affine linear space is a vector space that has forgotten its origin."
Dale said:"the point corresponds to the zero vector 0, called the origin"
Dale said:A vector space does in fact have an origin even if you restrict the origin to being a point and points to being elements of affine spaces.
Do you have something specific in mind? Hendrik should have the same qualifications.dextercioby said:@fresh_42 Can you read this with your (Germany-based) mathematical education and express your opinion to Dale, Peter and Hendrik?
fresh_42 said:I think the formal definition is: An affine space ##\mathbb{A}## with an underlying vector space ##\mathbb{V}## is the set of all points, which can be written as a difference of vectors from ##\mathbb{V}##.
fresh_42 said:There had been some strange statements about the word origin. I think it should be clear that the zero vector is meant.
That's why it makes sense, the difference is a vector, which makes the endpoints of the difference building vectors a part of the affine set.PeterDonis said:This doesn't make sense. The difference of two vectors is another vector, not a point. If you have a set of points, the difference between two points is a vector, but that's going from the affine space to the vector space, not the other way around.
Yes, that's what I meant with my example of tangent spaces if you avoid the vector field terminology.PeterDonis said:It was clear that that's what @Dale meant by "origin". But @vanhees71 was using a different definition of origin, the origin of a reference frame. You can certainly construct a correspondence between the two, as I described in post #27. But you do have to construct it.
fresh_42 said:the difference is a vector, which makes the endpoints of the difference vectors a part of the affine set.
The point is that you have to find a phrasing which doesn't use ##\vec{v}_0## in the definition, because this would bond the entire construction to an outer vector space where everything takes place. With the definition as difference, you avoid the kick-off and only need a vector space as reference.PeterDonis said:This seems to be basically the definition @vanhees71 was using.
fresh_42 said:The point is that you have to find a phrasing which doesn't use ##\vec{v}_0## in the definition
I do. It is exactly what I have said. Just with other letters.PeterDonis said:If you don't agree with the UPenn definition
fresh_42 said:let's go formal then
fresh_42 said:where ##a\in \mathbb{A}## if there are vectors ##\vec{u},\vec{v} \in \mathbb{V}## such that ##a=\vec{u}-\vec{v}##.
fresh_42 said:The point is, that you formally leave ##\mathbb{V}## and define a set of points instead. The difference does no longer belong to ##\mathbb{V}##.
Nonetheless, it does indicate that many scientists agree that a vector space has an origin.PeterDonis said:This just shows that this claim is fairly common. It doesn't show why it is true (if it is true)
It is when it agrees with valid sources, which it does in this case.PeterDonis said:Do I have to point out that Wikipedia is not a valid source?
No, it is arguing against representing a space of points as a vector space. I.e. it is arguing that the set of points is an affine space not a vector space precisely because a set of points do not have an origin and a vector space does. The source supports the claim that a vector space has an origin.PeterDonis said:In other words, this source is arguing against interpreting a vector space as a space of points, not for it.
Then it is time to close this thread. I have given valid references supporting my position and you have given none supporting the opposite, namely that a vector space does not have an origin. If we cannot even agree on what the literature clearly says then there is no point.PeterDonis said:I'm sorry, but I don't accept any of these references as supporting your position.
No qualification is needed. A vector space satisfies all of the axioms of an affine space, so it is both. I don’t think that German affine spaces have different axioms.vanhees71 said:You have to make the qulification that you interpret the vector space as an affine space in the above explained way. Otherwise it's not understandable, at least not for one trained in the German mathematical tradition.
UPenn is exactly the same, although terribly incomplete as quoted. I assume we are talking about the same vector of →EE→ which defines all the points. Then have ei+→v0∈Eei+v→0∈E and e1−e2∈→Ee1−e2∈E→. If you have varying vectors, then you get again the entire space including the origin.PeterDonis said:I still don't understand how this defines aa as a "point" instead of as a vector. If all you have is a vector space, the difference of two vectors is a vector, not a point.
No, I define the affine space as →v0+Vv→0+V. This isn't a vector space anymore. But the difference of two elements of this set is a vector.Your definition here, as far as I can tell, just defines the affine space AA as the vector space VV, since the difference of any two vectors in VV is just another vector in VV.
Dale said:No, it is arguing against representing a physical space of points as a vector space. I.e. it is arguing that the set of physical points is an affine space not a vector space precisely because physical points do not have an origin and a vector space does.
Dale said:you have given none supporting the opposite, namely that a vector space does not have an origin.
Dale said:A vector space satisfies all of the axioms of an affine space, so it is both.
Yes. That is why ##T_pM## is strictly speaking not a vector space, as its "origin" is ##p##. But we identify ##p## with the origin and call it a vector space. But this vector space ##\mathbb{V}## is actually ##T_pM=p+\mathbb{V}##, a vector space kicked off ##0## into ##p##. That's where the word origin gets confusing, and what you correctly mentioned: you have to construct ##p=\vec{0}##. In case of tangent spaces we have such a natural point, in GR not so much.PeterDonis said:Just to be clear: my argument has not been that a vector space does not have an origin. My argument has been that the definition of "origin" you are using when you say that a vector space has an origin is different from the definition of "origin" that @vanhees71 was using. You can construct a correspondence between them, as I've described (post #27), so, as I pointed out in response to @vanhees71, it is not "absurd" to make use of such a correspondence, but they're not the same definition.
fresh_42 said:UPenn is exactly the same, although terribly incomplete as quoted
fresh_42 said:I assume we are talking about the same vector of ##\vec{E}## which defines all the points.
fresh_42 said:I define the affine space as →v0+Vv→0+V. This isn't a vector space anymore.
fresh_42 said:That is why ##T_pM## is strictly speaking not a vector space, as its "origin" is ##p##.
fresh_42 said:this vector space ##\mathbb{V}## is actually ##T_pM=p+\mathbb{V}##, a vector space kicked off ##0## into ##p##.
PeterDonis said:In the UPenn definition, there is no such vector. There is a set of points ##E## and a vector space ##\vec{E}##. Both are given. Neither is defined from the other.
This is exactly when it becomes incomplete. If we have a set ##E## and a vector space ##\vec{E}## such that ##E=E+\vec{E}##, then how do you get rid of the self reference?PeterDonis said:The UPenn reference @Dale gave defines an affine space (Definition 2.1.1) as (omitting the degenerate case of the empty set) a triple ##< E, \vec{E}, +>##, where ##E## is a nonempty set, ##\vec{E}## is a vector space, and ##+## is a binary operation that adds a vector (member of ##\vec{E}##) to a point (member of ##E##) to get another point. The addition operation then has to have some simple properties.
fresh_42 said:If we have a set ##E## and a vector space ##\vec{E}## such that ##E=E+\vec{E}##,
Then what defines ##E##? When does a point belong to ##E##?PeterDonis said:That's not what the definition says. The definition says that we have a set of points ##E##, a vector space ##\vec{E}##, and an operation ##+## that combines a point from ##E## and a vector from ##\vec{E}## to get another point from ##E##. The operation does not define ##E##.
fresh_42 said:Then what defines ##E##?
fresh_42 said:I use location vectors, meaning their endpoints as point set
fresh_42 said:So why do you want to use it all the time
fresh_42 said:if it doesn't define the points of ##E##?
fresh_42 said:I still think UPenn means the end of the rope as the one point the entire plane is attached to.
Sure, that's what I'm saying: we have to find a definition which doesn't require the set-off ##v_0##. But we also need a criterion to decide whether a given point belongs to ##E## or not. We cannot list them. If we cannot decide membership to ##E##, then it is a useless definition.PeterDonis said:I don't think the UPenn definition is committing itself to any particular semantic model. It's just trying to define the abstract mathematical structure of an affine space.
fresh_42 said:we have to find a definition which doesn't require the set-off ##v_0##.
fresh_42 said:we also need a criterion to decide whether a given point belongs to ##E## or not.
