Age problem from Mathematical Conundrums
  • Level: Undergrad
  • Thread starter Thread starter Curious Kev
    Age Algebra Puzzle
38 replies · 10K views
Curious Kev
TL;DR
A puzzle with insufficient information.
This is from the front cover of Mathematical Conundrums, CRC Press, 2023.
<< When Holly was twice the age Ivy was 15 years ago, Ivy was half the age Holly will be in 12 years time.
How many years ago was that? >>
OK, but why isn't the age of Holly and Ivy given?
Mathematics news on Phys.org
Curious Kev said:
TL;DR Summary: A puzzle with insufficient information.
Why do you need their ages?
Can you set up the relevant Equations? Start with ##H## and ##I## as their current ages.
Nope, I can't. It's not insufficient information, it's contradictory information.
\begin{bmatrix}
1 & -2 \\
-\frac{1}{2} & 1
\end{bmatrix}
\begin{bmatrix}
H \\
I
\end{bmatrix}
\begin{bmatrix}
-30 \\
\end{bmatrix}
\begin{bmatrix}
1 & -2 \\
-\frac{1}{2} & 1
\end{bmatrix}
\begin{bmatrix}
H \\
I
\end{bmatrix}
\begin{bmatrix}
-30 \\
\end{bmatrix}
You've misread the problem.
Probably, I'm not surprised. Plus I don't think I can put LaTex inside a spoiler???
PS: Sorry, don't mean to derail the tread. I'll figure out LaTex later...
(h-15 = 2*(i-15) ) = (2(i+12) = h+12)
where h and i = are their current ages
I have clearly made a hash of the problem...
It's confusingly worded. Or it's easy to mis-read, anyway.
In addition to @PeroK's suggestion to write ##H## and ##I## as their current ages I suggest defining ##Y## as "the number of years ago that was" and then re-reading the question carefully.
Ibix said:
It's confusingly worded. Or it's easy to mis-read, anyway. In addition to @PeroK's suggestion to write ##H## and ##I## as their current ages I suggest defining ##Y## as "the number of years ago that was" and then re-reading the question carefully.
Yes, my problem is I haven't figured out how to compare the two equations. It's not by adding a third equal sign... :oldbiggrin:
DaveC426913 said:
Yes, my problem is I haven't figured out know how to compare the two equations
Your equations aren't right either, I'm afraid. I think you made the same mistake @DaveE made, only he wrote his equations in matrix/vector notation.
h-15 = 2*(i-15)
holly's age (h) minus 15 years
should be equal to
double (ivy's age (i) minus 15 years)
2(i+12) = h+12
holly's age (h) plus 12 years
should be equal to
double (ivy's age (i) plus 12 years)
Wait. This is what is being asked:
"How many years ago was that?"
That doesn't make sense. It was no years ago.
The answer is zero.
DaveC426913 said:
h-15 = 2*(i-15)
should be equal to
2(i+12) = h+12
should be equal to
No.
We probably shouldn't go too far down discussing the solution in this thread before the OP returns, so I'll just repeat my hint that you need to define ##Y##. PM me if you want to discuss further. 😁
It's clearly worded, just unusual. I did it by starting with four equations and five unknowns.
It's only two equations, surely?
For convenience, take the current year to be 0 and Holly and Ivy’s current ages to be H and I respectively.
The question's wording is confusing but seems to mean this:
In (unknown) year -x, Holly was twice the age Ivy was in the year -15.
Also in year -x, Ivy was half the age Holly will be in year 12.
There are three unknowns (x, H and I) but only 2 equations. However, it turns out (with only simple algebra) that there is a unique value for x (but not so for H and I).
The meta approach is to assume that there is a single solution for ##x## and take any value of ##H##.
To all - at the risk of further mudding the waters merely for my own edification:
Why is x anything other than zero?
One equation deals with events 15 years ago and the other deals with events 12 years hence.
What is forcing x to not be "now"?
Some detail I'm missing here.
The wording is (deliberately?) ambiguous. Consider the phrase:
"When Holly was twice the age Ivy was 15 years ago..."
The initial word "When" can be taken to mean"15 years ago".
Or it can be taken to mean "At some unknown time, x years in the past".
With the latter interpretation (and using the conventions noted in Post #15) the phase:
generates the equation:
H-x = 2(I-15)
That's because x years ago Holly's age was H-x. And 15 years ago, Ivy's age was I - 15.
The other part of the question:
"...Ivy was half the age Holly will be in 12 years time."
is referring to Ivy's age x years ago, generating the equation:
I-x = (H+12)/2
H-x = 2(I-15)
I-x = (H+12)/2
I don't see how that addresses my confusion.
The question is, essentially: "what is the reference year?" AKA Ibix's Y variable in post 9.
It seems a trick question, or goose chase - the reference year is arbitrary. We might as well pick 15 years after the first scenario and 12 years before the second scenario, since that's how the scenario is described. i.e. now.
So what am I missing? Clearly, what I am missing is the very crux of the riddle, so to forestall further clutterment, I will step back and lurk.
It seems a trick question, or goose chase - the reference year is arbitrary. We might as well pick 15 years after the first scenario and 12 years before the second scenario, since that's how the scenario is described. i.e. now. So what am I missing?
Let's say Ivy is 25. 15 years ago she was 10. The question refers to when Holly was twice that age. I.e. when Holly was 20.
When Holly was 20 she was twice the age that Ivy was 15 years ago. That seems clear enough.
It reminds me of the opening line of One Hundred Years of Solitude:
"Many years later, as he stood before the firing squad, Colonel Aureliano Buendia was to remember that distant time when his father took him to discover ice. "
Nice little problem!
Exactly, some nice cancellation will help.
Just passive-aggressively binged that last week.
Holy was twice the age Ivy means the same as Ivy was half the age Holy.
-- x ------------ x+12=now-15 --------------- now --->
The answer is 27 years.
If you think the answer to the question "How many years ago was that?" is 27, the answer is wrong.
That's not what the question says.
"When Holly was twice the age Ivy was 15 years ago, Ivy was half the age Holly will be in 12 years time"
Taking the current year as 2025, the question can be re-expressed as:
x years ago, Holly's age was twice (what Ivy's age was in 2010)
and
also x years ago, Ivy's age was half (what Holly's age will be in 2037).
Find x.
  • Wow
and
Find x.
The question is more clear now.
Not to me and @Curious Kev was on the site less that three hours regarding this question. That's bad form on pf Kev.
So, that is three days since I was 4 times more interested than @PeroK will be in the half the time @DaveC426913 was yesterday. What is my name?
Also can someone do a break down with all the equations because I do not understand how to get a value for T as a date.
What does 27 mean?
I missed a Teams because of this.
  • Haha
H-x=2(I-15)
I-x=(H+12)/2
H-x=2I-30
H+12=2I-2x
12+x=-2x+30
3x=18
x=6
The correct answer is 6 years ago.
Gavran said:
H-x=2(I-15)
I-x=(H+12)/2
H-x=2I-30
H+12=2I-2x
12+x=-2x+30
3x=18
x=6
Yeah that's the one on stack I think. I think I don't like the word "ago."
Should it be "before?"
