B Air Horn Physics: Calculating Size, Length & More for Musical Chords
  • B
  • Thread starter Thread starter Grant M
    Air Physics
The discussion centers on designing air horns that produce specific musical notes, focusing on the relationship between horn dimensions and sound frequency. Participants emphasize that the length of the horn is crucial for determining pitch, while the shape of the bell affects sound quality and amplification. Resources are shared for understanding horn theory and calculating dimensions, although some participants note the complexity of the physics involved. The project aims to create locomotive horns that can produce musical chords at specific decibel levels. Overall, the conversation highlights the challenges of acoustics in designing effective air horns.
Grant M
Hi. I am new to this forum and would like to get some information on the physics of an air horn. I am trying to design a series of air horns that each play a musical note. The problem I'm running into is what size to make each trumpet in order to produce a specific note. I know that frequency is related to length and width but I can't find an equation to use. The horns work pneumatically by a vibrating diaphragm. Ideally I'd like to use one specific dimension for the base of the bell and just vary the length to change the pitch.
I am looking for the following info:
-Calculating the total length of a horn from frequency
-The best shape of bell to use for a horn for harmonics (equation for the exponential horn bell)
-Calculating the size based on a 5" diaphragm
-other factors that I should take into consideration
The purpose of this project is to create a line of locomotive horns that play musical chords. Each set of horns will include 3-5 trumpets and must produce 96-110dB at 100ft.
Thanks for your help on this. :)
The physics is not simple ... though the fundamental is mainly to do with the tube length. The flair at the end is mainly for amplification.
The specifics of the shape give you the type of sound.
Or perhaps the simple physics isn't close enough to right?
Try this:
https://www.grc.com/acoustics/an-introduction-to-horn-theory.pdf
But you may not like it!
Likes Simon Bridge
Try this:
This PDF seems to be more of an speaker horn rather than a brass instrument. I need to figure out how to calculate the natural frequency of a horn from the dimensions. These air horns operate on basically the same principle as a trombone except with a diaphragm producing the vibration.
Grant, did you find the information you needed? I would love to know how your project is going. This idea has been a decades-long interest of mine.
anorlunda said:
I think pipe organs and air horns are pretty much alike.
I think the Vox Humana pipe in an organ is the most like an air horn. A reed is used at the end of a pipe. But the pipes are not tapered so they don't have a wide band match, like a tapered horn and the higher harmonics / overtones are not as pronounced as with an air horn.
