Algebra, percentages bank interest problem (simple)
4 replies · 2K views · last reply
Femme_physics
Well, it seems simple, anyway, but I'm not sure why my methodology would be wrong.
In a certain bank they offer 2 saving accounts.
Plan A gives an annual interest of 6%
Plan B gives an interest of 12% once every 2 year.
What's the preferable plan if you want to invest money for 4 years? Explain.
Attached. X is defined as "original amount".
  • Handwritten working on graph paper: 'Yearly plan: X + (X·0.06)4 = 0.24x + X' above '2-years plan: X + (X·0.12)2 = 0.24x + X', with both results boxed, an arrow pointing down to the note 'It's the same!'
I'm not sure how banks work, but I think that in this case, after a year you'll get 6% of X and then the next years you'll get 6% of (6% of X + X). I think this is called compound interest, but I'm not sure this is the case with your problem.
Well, it must be the case since mine is not the right answer. I'll try it your way. Thanks :)
I think you have to use the compound interest formula
[tex]A(t) = A_0 \left(1 + \frac{r}{n} \right)^{nt}[/tex]
where
A0 = the principal
t = time in years
n = number of compounding periods per year (monthly: n = 12; quarterly: n = 4...)
r = interest rate expressed as a decimal
Have you seen this equation before?
I just used the long route to get to the solution. (attached)
Good thing they didn't ask for the next 2000 years or I'll have been writing it till next week...
But yea, it's best I use this formula next time. I think I've seen it before, but I haven't applied it. I really should, to save time. Thanks.
  • Handwritten solution in Hebrew on graph paper comparing a yearly 6% plan with a biyearly 12% plan over four periods, concluding X yearly is greater than Y yearly.
