Algebra Problem with Rationals and Proofs
  • Thread starter Thread starter silvermane
    Algebra Proofs
The discussion revolves around proving two algebraic statements involving rational numbers and square roots. For part a, participants suggest that if a + b√2 = c + d√2, then both a must equal c and b must equal d, as any non-zero difference would lead to a contradiction. In part b, the focus is on proving that a² - 2b² is non-zero unless both a and b are zero, with hints to factor the equation and utilize results from part a. The conversation highlights the importance of recognizing the rational and irrational components in the equations. Overall, the contributors provide encouragement and clarification to help solve the problems effectively.
silvermane
Hello fellow forum buddies :)
a.) Prove that if a+b\sqrt{2} = c+d\sqrt{2} with a,b,c,d all in Q, then
a = c and b = d.
b.) Prove that a^2 - 2b^2 with a, b in Q is nonzero unless a=b=0
I really don't know where to start. Any tips would be nice. I just need to see something that I'm not seeing at the moment. :(
I don't need an answer, just a little jolt lol. It will be greatly appreciated! :)
For part a, is (a-c) in Q? Is (b-d)\sqrt{2}?
For part b, factor the equation and try to use the result from part a.
I guess he ^ already took care of you ;-).
Post again if you need more clearification.
AHHH... wow I'm glad I see it now. So I just need to solve a and c with respect to the fact that they are rational, then b and d with the fact that they're not rational?
Awe phanku :)
b and d are rational, however, the product with sqrt(2) is not. I believe this is what you meant.
I believe you can see that if b-d was non-zero a contradiction ensues. :-)
EDIT
lmao.
U r velcome :-).
Well if x = a - c is nonzero, can we find y such that x = y \sqrt{2}? Is such a y compatible with y = b-d?
Ahhhh that should do it lol. I wrote that down and when I saw each of your replies, it was confirmed. I think I can finish it from here. Thanks so much! :)
Okay. Post if you get stuck in part b or something.
