Algebra Simplification: Solving for X with Conjugates
  • Thread starter Thread starter Axecutioner
    Algebra
3 replies · 3K views
Axecutioner
Problem:
[PLAIN]http://img40.imageshack.us/img40/1020/gahr.png
I need to simplify the x equation as far as I can, the y equation is x multiplied by it's conjugate, and the z equation is a failed attempt at further simplification. The last line is me checking which of the 3 (x, y, and z) equations are equal.
Basically, I need to take the y equation, keep not change the y at all, and get the other side simplified as much as I can.
Thanks!
Well, first off:
I don't see how "y" is a simplification of "x", or that the corrected "z" would simplify anything.
Stick instead with your "x" formula, and you may rewrite this, if not simplifying, as:
[tex]x=\frac{\sqrt{\frac{A}{B}}(\sqrt{\sin^{2}\theta-\frac{C\sqrt{B}}{\sqrt{A}}})+\sin\theta}{B}[/tex]
This should also tell you where you went wrong in your "z"-expression.
Thanks, that looks better. But uh...
Plug in the numbers I did in my x equation and you get 0.8164965809...
(2/3)^.5 = 0.8164965809...
So somehow my x equation simplifies to just (A/B)^.5
Well, it doesn't.
For example, with your "x"-expression, setting C=theta=0 makes x=0, rather than equal to the square root of A/B
