Troubleshooting Algebraic Anomaly: Why x = -1 Doesn't Work? | Basic Algebra Tips
  • Thread starter Thread starter terryds
    Anomaly
The equation x - √((x+2)²) = 0 leads to the solution x = -1 through algebraic manipulation, but this value does not satisfy the original equation. The issue arises from squaring both sides, which can introduce extraneous solutions that do not hold true in the context of the original equation. It is essential to verify any solutions obtained from such operations by substituting them back into the original equation. Ultimately, the discussion concludes that the original equation has no valid solutions, as confirmed by checking the derived solutions against the equation's constraints.
terryds
I want to find x that satisfies ##x-\sqrt{(x+2)^2} = 0##
Using algebric method, I find x = -1
But, x = -1 does not satisfy that equation...
What's wrong with the calculation?
(Basic algebra)
##x-\sqrt{(x+2)^2} = 0 \\
x = sqrt{(x+2)^2} ##
By squaring both sides , I\ get
##x^2 = (x+2)^2 \\
x^2 = x^2 + 4x + 4 \\
0 = 4x + 4 \\
x = -1 \\
What's wrong with this ?
The equation you want to solve does not have a solution to begin with.
So, does it mean that it's necessary to plug the solution that I get from algebric calculation into the equation to confirm it's true??
(Basic algebra)
##x^2 = (x+2)^2 \\
0 = 4x + 4 \\
x = -1 \\
When you square both sides of an equation, there's the possibility that you'll get an equation whose solutions are not the same as the original equation. In this case, squaring introduced an extraneous solution.
Yes
Likes terryds
Hmmm..
So squaring both sides is a wrong attempt to find the solution ?
I wonder if there are any article about to-dos and not-to-dos in solving particular algebraic equations...
terryds said:
Hmmm..
No, this is the right approach. It's just that when you apply any non-reversible operation (such as squaring, raising to fourth power, etc.), you need to check to see if you have introduced extraneous solutions.
You might try doing a search for "extraneous solutions". Most algebra textbooks mention this in the section where equations involving radicals are presented.
Likes terryds
For this equation, you can actually still work in a way which does not introduce any extra solution. Note that you can cast the original equation into ##x-|x+2|=0##. Solve this equation for ##x<-2## and ##x>-2## to see if there is a solution in each region.
Thanks a lot!
x-x+2 = 0 (No solution)
x+x+2=0
2x+2=0
x=-1 (Still an extraneous solution)
terryds said:
x-x+2 = 0
x-x-2=0
terryds said:
x+x+2=0
2x+2=0
You forget that you are looking for a solution in ##x<-2##. The solution you find there lies outside this range.
blue_leaf77 said:
x-x-2=0
So it means no solutions, right ?
Yes.
terryds said:
I want to find x that satisfies ##x-\sqrt{(x+2)^2\,} = 0##
Using algebraic method, I find x = -1
Suppose you were to solve ##\ x+\sqrt{(x+2)^2\,} = 0\ ## and you used the same method.
That is equivalent to ##\ \sqrt{(x+2)^2\,} = -x\ .##
Squaring both sides gives ##\ (x+2)^2 = x^2\ ##, the same as in your case, giving ##\ x=-1\ .## Here the solution is valid.
