MHB Algorithm with ceil(n/2) comparisons
  • Thread starter Thread starter evinda
    Algorithm
The discussion revolves around designing an efficient algorithm to find the minimum element in a strictly alternating sequence of numbers, defined by specific conditions for the sequence's elements. The algorithm aims to achieve this with at most ⌈n/2⌉ comparisons. Participants explore various implementations, focusing on initializing the minimum value based on comparisons between the first two elements. The algorithm iterates through the array, skipping every other element to reduce the number of comparisons. Key points include the realization that tracking the index of the minimum value is more efficient than storing the value itself. The final analysis clarifies that the number of comparisons needed aligns with the expected complexity of ⌈n/2⌉, whether n is even or odd. The discussion emphasizes the importance of simplicity in coding for clearer analysis and correctness, ultimately confirming the algorithm's efficiency in finding the minimum element in the alternating sequence.
evinda
MHB
Hello! (Wave)
I am looking at the following exercise:
We say that a sequence of numbers $A=(a_1,a_2, \dots, a_n) , n \geq 3$, is strictly alternating if for each $i$, with $2 \leq i \leq n-1$, one of the following conditions stands:
  • $a_{i-1}< a_i$ and $a_i>a_{i+1}$
  • $a_{i-1}>a_i$ and $a_i<a_{i+1}$
For example, the sequences $(2,10,5,6,3,11,-1,7,4)$ and $(2,-7,4,3,6,0,33,2)$ are alternating, but the sequnce $(5,6,7,3,4,-2,7,10)$ isn't.
Design an algorithm, that, given an alternating sequence of numbers $A$, executes at most $\lceil \frac{n}{2} \rceil$ comparisons, in order to calculate the minimum element of $A$. Justify your answer.
I wrote the following code:
Code:
#include <stdio.h>
int main()
int n,i,min,position_min;
printf("Give n: \n");
scanf("%d",&n);
while (n<3){
   printf("	Give an other value for n: \n");
   scanf("%d", &n);
int A[n];
for (i=0; i<n; i++){
     printf("Give the value of the %dth position of the array: \n",i+1);
     scanf("%d",&A[i]);
min=A[0];
position_min=0;
if (A[1]<min) {
    min=A[1];
    position_min=1;
for (i=position_min+2; i<n; i+=2){
    if (A[i]<min){
       min=A[i];
       position_min=i;
printf("min=%d \n ",min);
return 0;
So, we need $2 \left ( \frac{n-\text{position_min}-2+1}{2} \right )=n-\text{position_min}-1$ comparisons..But.. we don't need $\lceil \frac{n}{2} \rceil$ comparisons, at the algorithm I wrote.. (Sweating)
How could I do it otherwise? :confused:
Technology news on Phys.org
If the first number is smaller than the second then you have the indecies are even. Otherwise they are odd.
You don't need to store the value of the element but rather you store the index.
For example :
Code:
A = {4,6,5,7,3,8,2}
Then min is initialized to 0 since 4 <6.  counter =2;
Since A[min]<A[counter] , min stays 0;
Counter = counter+2 = 4;
Since A[min]>A[counter] min=4;
Counter = counter+2=6;
Since A[min]>A[counter] min=6;
Counter = counter+2=8 > length(A)
Hence min = 6 and the minimum is A[6]=2;
Since each time we travel almost to the end of the array and we skip one element at a time we expect the complexity to be $$\frac{n}{2}$$.Fore the case were the first element is greater than the second initialize min=1 and counter = 3.
For example :
Code:
A = {4,6,5,7,3,8,2}
So, at this for loop:
Code:
    if (A[i]<min){
       min=A[i];
       position_min=i;
we don't need to write the command:
Code:
position_min=i;
, right? (Thinking)
So,should it be like that? :confused:
Code:
#include <stdio.h>
int main()
int n,i,min,j;
scanf("%d",&n);
while (n<3){
   scanf("%d", &n);
int A[n];
     scanf("%d",&A[i]);
min=A[0];
j=0;
if (A[1]<min) {
    min=A[1];
    j=1;
for (i=j+2; i<n; i+=2){
    if (A[i]<min){
       min=A[i];
return 0;
Generally we are not interested in the element but rather the index so we have
Code:
if(A[0] < A[1])
    min=0;
else
    min=1;
for(counter = min+2; counter < n ; counter+=2)
    if(A[counter] < A[min])
          min = counter;
printf("The minimum is %d ", A[min]);
Code:
if(A[0] < A[1])
    min=0;
else
    min=1;
          min = counter;
So, we need $n-min-2+1=n-min-1=\left\{\begin{matrix}
\frac{n-1}{2} &, min=0 \\
\frac{n-2}{2} & ,min=1
\end{matrix}\right.$ comparisons, right? (Thinking)
But.. how can we show that we need $ \lceil \frac{n}{2} \rceil$ comparisons? :confused:
Just don't bother only checking the last element if min = 0, do it every time. It doesn't affect correctness, and makes your code simpler to analyze, because in that case you simply have this number of comparisons:
$$1 + \left ( \left \lfloor \frac{n}{2} \right \rfloor - 1 \right ) + (n \bmod 2) = \left \lfloor \frac{n}{2} \right \rfloor + (n \bmod 2)$$
Where the first $1$ is the initial comparison, the second term is the for loop (note that you must subtract $1$ because you've already processed the first two elements) and the final $n \bmod 2$ is because we need one more comparison if $n$ is odd for the last element.
If $n$ is even, then this gives:
$$\frac{n}{2} = \left \lceil \frac{n}{2} \right \rceil$$
And if $n$ is odd, then this gives:
$$\frac{n - 1}{2} + 1 = \frac{n + 1}{2} = \left \lceil \frac{n}{2} \right \rceil$$
And so you are done. Sometimes it pays off to not be too clever :)
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
