Alternative theories being tested by Gravity probe B
371 replies · 137K views · last reply
Garth said:
The references are: Weinberg "Gravitation and Cosmology" 1972:
The Lense-Thirring, "frame dragging" effect,
page 248 equation 9.928 and the line following:
And for the geodetic effect,
page 238 equation 9.6.24 and the next line which gives:
Now in BD (Weinberg equation 9.9.27):
[tex]\gamma = \frac{\omega + 1}{\omega + 2}[/tex]
so the geodetic effect is to multiply the GR result by a factor:
[tex]\frac{3\omega + 4}{3\omega + 6}[/tex]
So your calculation was not too far out.
Garth
Come off it Garth. The issue is not my calculation. It that we now have two difference references, using different formulae for the geodetic effect.
Thanks for your reference; I'll see if I can find it, and add it to the list I'm keeping of different predictions.
In the meantime, if you are interested, you may like to look over the reference I used, by Nandi et al. You are probably much more familiar with Brans-Dicke than I am, and I'd certainly appreciate it. The paper at Brans-Dicke corrections to the gravitational Sagnac effect (gr-pq/0006090) is proposing a fix to geodetic that is as I described previously. It's not that my calculation is "not too far out". It is that I'm calculating correctly the formulae as given in a different paper.
There is a factor 2/3 floating around. If you do get a chance to look at this paper by Nandi et al, then look at equation 110, which gives the geodetic effect; and the equation 98, which gives parameters in terms of ϖ, and the final paragraph, which summarizes the prediction.
Now perhaps this is yet another different prediction. I don't know. They claim to be using Brans-Dicke, and it is a fairly recent paper that explicitly mentions Gravity Probe B and the expected result. The paper also appeared in Phys Rev D.
Anyone else who can identify the discrepancy please feel free to help out also.
Cheers -- Sylas. 6 days and counting
Astronomy news on Phys.org
Sylas I have read that paper in some depth and have a question about its method.
The basic equation they use for the Sagnac effect, equation1, is a SR effect well tested on ring laser interferometers.
However, they seem to be explaining a curvature effect by a SR flat space-time one.
In BD the correction is due to the perturbation of the curvature of space-time caused by the presence of the scalar field.
As the Sagnac effect is a time delay, is that not already taken care of in the time component of the GR formulae (i.e. the component not dependent on [itex]\gamma[/itex])? i.e. If applicable in the GR case it is only an alternative description of the same effect and should predict the same geodetic precession. (As it does for frame-dragging)
But note that your calculation of their geodetic effect, ([itex]\omega[/itex] + 1)/([itex]\omega[/itex] + 2), is simply [itex]\gamma[/itex]. Now [itex]\gamma[/itex] measures the amount of space curvature per unit M (actually, per unit GM) so their interpretation of the geodetic effect is a purely a space curvature one, the time dilation component has dropped out! I don't think this can be correct as the essence of GR and similar metric theories of gravity is that gravitation is a space-time and not just a space curvature effect.
Any difference between the formulae might then simply be due to an inappropriate application of the Sagnac effect.
Note with the BD [itex]\omega[/itex] ~ 500 their BD correction to the GR prediction is ~ (1 +/- 2.10-3), whereas the Weinberg BD correction is ~ (1 - 10-3)
I too am counting!
Cheers,
Garth
Hello everybody,
First of all, I apologize for my way of writing in English. I hope it won't be too hard for you to understand what I say.
I am a french physicist from Montreal (B.Sc. Physics, 1974, University of Montreal, M.Sc. Physics partly completed, 1976, University of Montreal)
This thread is much interesting. I myself work on a theory of mine since a couple of years. My theory is not primarily concerned with gravitation: it is a theory that is based on a deterministic model of the physical world with nonlocal hidden variables identified explicitly. But in the end, this theory leads to a new model of gravitation. Regarding GP-B, my theory makes the same predictions as GR about geodetic effect and frame-dragging effect. But it predicts things that are different from GR and that could maybe be confirmed by that experiment, mainly:
1- flatness of 3-D geometry
2- universal "cosmological redshift" of momentum (including the momentum of gravitationally bound objects)
3- a phenomenon that leads to "shifts" in signal frequency (like the one observed in the Pioneer Anomaly)
My theory has never been published in a peer reviewed journal nor on arXiv, and I could not even publish it right now in your independent Research Forum. So I don't expect it to be listed in your list. I just wanted to give my own predictions before the public announcement of the GP-B results, rather than giving it after :wink:
Friendly
Paul Le Bourdais
Hi Paul and bienvenue to these Forums!
You might try to put your theory onto the Theory Development Forum, the discipline may help you progress with it.
But as you say it hasn't been published and that its GP-B predictions are the same as GR we will leave it off this thread.
Garth
Thanks to you Garth.
It's okay for me, I understand very well.
Paul
As there are only 4 days to go I here re-post all the accepted predictions for comparison with the first results due to be announced on Saturday 14th April at the April APS meeting.
These theories and their predictions of the Gravity Probe B experiment have all been published in refereed journals, or on the Physics ArXiv. Most of them make specific and falsifiable alternative predictions of the outcomes.
  1. Einstein's General Relativity(GR)
  2. Brans-Dicke theory (BD)
  3. Barber's Self Creation Cosmology (SCC),
  4. Moffat's Nonsymmetric Gravitational Theory (NGT),
  5. Hai-Long Zhao's Mass Variance SR Theory (MVSR),
  6. Stanley Robertson's Newtonian Gravity Theory (NG),
  7. Junhao & Xiang's Flat Space-Time Theory (FST).
  8. R. L. Collin's Mass-Metric Relativity (MMR) and
  9. F. Henry-Couannier's Dark Gravity Theory (DG).
  10. Alexander and Yunes' prediction for the Chern-Simons gravity theory (CS).
  11. Kris Krogh's Wave Gravity Theory (WG)
  12. Hongya Liu & J. M. Overduin prediction of the http://www.journals.uchicago.edu/ApJ/journal/issues/ApJ/v538n1/50681/50681.text.html?erFrom=5252751197746712308Guest#sc8 gravity theory (KK).
  13. Kerr's Planck Scale Gravity: now accepted for publication Predictions of Experimental Results from a Gravity Theory (PSG)
The predictions are:
A. GPB Geodetic precession (North-South)
  1. GR = 6.6144 arcsec/yr.
  2. BD = [itex](3\omega + 4)/(3\omega + 6)[/itex] 6.6144 arcsec/yr. where [itex]\omega[/itex] >6.
  3. SCC = 4.4096 arcsec/yr.
  4. NGT = 6.6144 - a small [itex]\sigma[/itex] correction arcsec/yr.
  5. MVSR = 0.0 arcsec/yr.
  6. NG = 6.6144 arcsec/yr.
  7. FST = 4.4096 arcsec/yr.
  8. MMR = -6.56124 arcsec/yr.
  9. DG = 6.6144 arcsec/yr.
  10. CS = 6.6144 arcsec/yr.
  11. WG = 6.6144 arcsec/yr.
  12. KK = (1 + b/6 - 3b2 + ...) 6.6144 arcsec/yr. where 0 < b < 0.07.
  13. PSG = 0.0000 arcsec/yr.
B. GPB gravitomagnetic frame dragging precession (East-West)
  1. GR = 0.0409 arcsec/yr.
  2. BD = [itex](2\omega + 3)/(2\omega + 4)[/itex] 0.0409 arcsec/yr.
  3. SCC = 0.0409 arcsec/yr.
  4. NGT = 0.0409 arcsec/yr.
  5. MVSR = 0.0102 arcsec/yr.
  6. NG = 0.0102 arcsec/yr.
  7. FST = 0.0000 arcsec/yr.
  8. MMR = -0.01924 arcsec/yr.
  9. DG = 0.0000 arcsec/yr.
  10. CS = 0.0409 arcsec/yr. + CS correction
  11. WG = 0.0000 arcsec/yr.
  12. KK = 0.0409 arcsec/yr.
  13. PSG = 0.0409 arcsec/yr.
The guide star IM Pegasi has a proper motion given by the http://archive.ast.cam.ac.uk/hipp/hipparcos.html:RA (J1991.25) : 22h 53m 02.279"
DEC (J1991.25) : +160 50' 28.540"
Proper motion in RA : -0.02097 [itex]\pm[/itex] 0.00061 arcsec/yr.
Proper motion in DEC : -0.02759 [itex]\pm[/itex] 0.00057 arcsec/yr.
mag : 6.033 (HIPP)
MK spectral class : K1III SB (HIPP)
Of course, these alternative theories have to pass all the other tests of GR as detailed in Clifford Will's paper The Confrontation between General Relativity and Experiment.
Again I emphasise that some of them may well have already failed one or more of those tests.
Signing off for now...
Garth
LeBourdais said:
24 Hours to go !
Good luck everyone :smile:
Paul
Hi everybody,
You correct me if I'm wrong but GP-B annouced
- Having measured the geodetic effect at the percent level of accuracy
- Have not been able to extract the frame dragging signal yet (they give a 200% error and want to work until december to deliver the final results)
Concerning the frame dragging effect i would have appreciated if they had given at least a preliminary central value...however if i take (too much?)serious the GP-B experimental error poster, the west-east drift rate is reported for gyro2. Though i can see peaks (resonances) oscillating in between the -0.3 and +0.4 arcsec/year , the red plot where the resonances are mitigated seems to indicate that the frame dragging is compatible with zero!(for sure it is incompatible with the GR prediction! )...if some GP-B expert is around, please correct my feeling if I'm wrong.
Best regards
F H-C
Best regards
F H-C
There's no point giving a central value. The errors are reported as being around 100 mas/y, which is two and a half times the GR prediction. In other words, if it is compatible with 0 then it is also compatible with GR. Expertise in GR is not required and indeed completely irrelevant. Expertise in GR can only tell you what the GR predition is; what you need now is expertise in tracking the experimental errors and removing systematic effects. You're wrong in saying anything "for sure" about confirming or refuting the GR prediction of framedragging.
Cheers -- Sylas
Can someone give me a link or links to where the GP-B results are reported?
Many thanks,
Kris Krogh
Indeed but that is not what Frederic referred to, he referred to GP-B experts.
Actually, I would prefer not to have GR experts "explain" the errors, I like to have a completely theory independent view on these errors.
I don't think anyone is interested in another "Eddington" determining which errors are relevant and which not.
Oops! My apologies. I echo his request, then! I'd love to hear from a GP-B expert also.
What I want to know is why there is a difference between the prediction in the http://einstein.stanford.edu/content/press_kit/hi_res.pdf (6606 NS, 39 EW).
All numbers in milliarcseconds/year.
I'm guessing orbit parameters; since about an extra 3.5 km in altitude would give that kind of difference, I think. But I need a GP-B expert to confirm for me.
Cheers -- Sylas
Cheers -- Sylas
Sorry sylas but i have nothing to say "for sure" ! ...since I'm not a prophet...though i must admit I'm very confident in my approach
since on many other (theoretical and experimental) grounds i find it really more satisfying than GR and this I'm ready to discuss in details with anybody (by the way i already had many such discussions in french forums and private communications but very few in english since i don't feel really at ease with my english)... Do you or other people you know find my work or behaviour suspicious in any way ? ...i'm ready to answer any question!
I was just noticing here that generally, whatever the error, it is meaningfull to give a central value and most of the time it is given in any measurement..so i was just wondering what the absence of this central value means here (unfortunately i could not attend the APS meeting). I thought that may be the answer was in the plot of the L1 session i was asking clarification about. Please let me reformulate the question.
At least, is it true that the left/down plot in the L1 poster session :
L1.00027: "Gravity Probe B Experiment Error" by Barry Muhlfelder, G. Mac Keiser, John Turneaure
( Garth, you will find this poster online at http://einstein.stanford.edu/ )
shows the final east-west drift rate for gyro 2 after subtraction of some well understood dominant systematical effects (it remains these resonance peaks which magnitudes are used as the main error estimators) or is it something else ? What do the plots for other gyros look like?
best regards,
F H-C
Curved spacetime -> Black Holes -> BigBang
I wrote lots of papers and chatted on many forums but no one challenge my points:
1. GR is nothing but curved spacetime;
2. On curved spacetime, coordinates are not the accurate values of spatial distance or temporal interval or spatial angle.
3. To have those accurate values we need to perform integration with metric form being integrand. However, I did not see anyone do so to achieve distance, or angle, or time interval on curved spacetime. Instead, people simply write r, t, \phi and assume they are distance, time, angle respectively.
I am driven crazy by this fact with which many great figures (Einstein, Hilbert, John Baez, Steve Carlip, Francis Everitt being associated.
You can not say spacetime is curved because you have the terminology with some quantities: metric, cutvature, covariance. For example, quantum mechanics uses distance, radius which do not mean we can have definite orbits of micro-particles!
Is there anyone answering my question??
I agree with F H-C that the central value for this data should have some meaning. (Not only because our theories make the same predictions.) It certainly would be interesting to see the east/west drift rates for the other three gyros.
Also, the "Next Steps" section of the same poster describes the current error as 50-100 marcsec/yr. Previously, the GP-B people have used a single number like this to describe combined errors for both the east/west and north/south directions. If that's the case here, the east/west component might be still lower.
At least from a naive inspection, this chart does appear to show the east/west (frame-dragging) effect is close to zero, rather than the 41 marcsec/yr predicted by general relativity.
The NASA press release also puts the current estimated GP-B error at 50-100 marcsec/yr, as opposed to a specific 100.
The very fact that the GP-B estimated error has itself a great margin of error (75 ± 25 marcsec/yr) excludes the possibility of giving any meaning to a central value. Am I wrong ?
General relativity predicts 41 marcsec/yr. Suppose the measurement were -75 ± 75 marcsec/yr. That would rule out general relativity, while a zero precession would remain possible. So the central value does have meaning.
A previous GP-B web page said the best current estimate of the gyro motion relative to the guide star would be presented. The chart in the "GP-B Experiment Error" poster shows an east/west drift rate averaging about zero. I'm hoping that's relative to the guide star's motion, as previously measured -- but maybe it's not. With the guide star moving, certainly the drift is not zero in absolute terms.
Maybe that chart is the result after subtraction of any cumulative drift. But I hope they will follow through and tell us the central value for the drift, and not only the error.
The link that henryco has given for the poster on errors is goes to the GP-B site, from which you must navigate to the poster. The direct link for the poster is GB-P Experiment Error: A Work in Progress (L1.00027).
I gather that the error is an absolute error of comparable magnitude both North-South and East-West; this would mean that the East-West signal is swamped by the errors, and the North-South is obtained to about 1% or thereabouts.
Hm. Yes, I see what you guys are getting at. Here's a grab of the chart.
What is this measuring? If it is simply the East/West drift, then indeed the red line is well below the GR prediction of 0.039 (or 0.041, depending on what predictions you read!).
But directly below the grap is that sentence "Impact on experiment error 100 marcsec/yr". This value of 100 is 0.1 on the left hand axis, which is way off the whole scale. I'm not getting this.
Cheers -- Sylas
Hi Sylas,
To give you an example, the guide star moves east/west about -28 marcsec/yr, and -21 marcsec/yr north/south. The Gravity Probe B folks have described it as moving 35 marcsec/yr. That's the total magnitude -- squaring and summing the two values and taking the square root.
If the total current error were 50 marcsec/year in magnitude, it's conceivable the east/west component is significantly less. Maybe were're getting down in the range of 41 marcsec/yr predicted by general relativity.
Cheers,
Kris
Hi Kris,
The central value here has a meaning only for the combination of three effects (frame-dragging, “polhode” motion and "patches" torques) and the contribution from each of these effects is obviously not still known.
As they say on the "Gravity Probe B" site :
The GP-B instrument has ample resolution to measure the frame-dragging effect precisely, but the team has discovered small torque and sensor effects that must be accurately modeled and removed from the result.
Paul
Hi Paul,
When these extraneous influences like the polhode motion are estimated, of course that's done separately from the frame-dragging they are trying to measure. The latter is whatever is left when everything else has been accounted for.
This preliminary result is of the form x ± 100 marcsec/yr or x ± 50 marcsec/yr, where x has to be some specific number. (It can't be anything from -1000 to +1000, or you'd have an uncertainty of ± 1000.) Question is, what is x?
Best wishes,
Kris
Hi Kris,
You surely have read in my thoughts :biggrin: About one hour ago, I sent an e-mail at the contact address provided on the GP-B official site and I asked the question:
The margin of error for GP-B is told to be 50-100 marcsec/yr. The question I would like to ask is the following: is there any best value for the frame-dragging effect ? That is, can we say the result for the frame-dragging effect is X more or less 50-100 marcsec/yr, X being the best value. If so, is that value of X available ?
I hope I will get an answer :wink:
Best wishes,
Paul
Does anyone know the spin axis orientation for each of the four gyroscopes ?
LeBourdais said:
Hi Kris,
Best wishes,
Paul
Hi everybody
I also sent an email but received no answer so far.
This plot is very intriguing since it is clearly there to show us and explain to us what is the main source of uncertainty: the 100 marcsec/year.
This is why i believe that the resonance peeks we can see regularly spaced on the plot actually give us the order of magnitude of this error and indeed the higher peeks reach the 40 marcsec level (what else in this plot could justify the 100 marcsec given just below it?). If they don't understand at all what is the origin of these peeks, they can give the most pessimistic error: approximately 2.5 times 40 marcsec. ANother question is: is the reported
drift rate integrated from the origin to the bin time ? Presumably not (it would be indicated) so that the integrated drift rate at the end time must be very close to zero!
But what is even stranger here is that whatever the magnitude of the peeks, the very low dispersion of most points about the mean value and the ability to identify the peaks, subtract them and provide us with a mitigated red fit is a clear indication that whatever value was subtracted before, the error on the mean residual is extremely better than 100marcsec! and since other sources of errors are negligible compared to this one (the other errors are on the same poster) , my feeling is that they
were able to give a much better error but they decided not to give it and not to give also a central value. If the central value is at zero at the milliarcsec precision level, this might indicate a huge overestimation of the error already enough to produce a kind of earthquake in the community...so may be they want to work 8 more monthes to be sure since this would be a revolutionary
result! Is there some GP-B expert around?
regards
Fred
henryco said:
Hi everybody
Salut Fred :biggrin:
I think it's a good thing that more than one people ask them for the same question.
Best wishes
Paul
Even though the results are preliminary, some theories appear to have been eliminated. Anyone care to write up a synopsis?
Anything that did not give about 6.6 for the geodetic precession is falsified. We can ignore the frame-dragging predictions as so far not able to be tested.
Here is Garth's list.
Based on this we have models 3, 5, 7 and 8 as falsified.
The paramaterized models 2, 4 and 12 simply have a new constraint on the free parameter.
The remaining models are:
  • GR (1)
  • Parameterized models, which are the same as GR in the limit. 2,4,10,12: BD, NGT, CS, KK.
  • Models with frame dragging at 25% of what GR expects. 6: NG
  • Models with no frame-dragging. 9,11: DG, WG.
Cheers -- Sylas
Hi Paul,
The spin axes of all four gyros were aligned with IM Pegasi. These are its coordinates, posted previously by Garth:
Kris
