The discussion revolves around the comparison of Rockwell B and Rockwell E scales for measuring the hardness of aluminum alloys. Participants explore the applicability, accuracy, and practical considerations of each scale in the context of aluminum alloy testing.
- Debate/contested
- Technical explanation
- Some participants suggest that Rockwell B has a wider range of applicability based on test comparison data.
- Others note that Rockwell B uses a 1/16" steel sphere at 100 kg, while Rockwell E uses a 1/8" steel sphere at the same load, which may influence the choice depending on specimen thickness.
- A participant mentions a rule of thumb that the specimen thickness should be ten times the indentation penetration, indicating that Rockwell E may allow for measuring thinner specimens than Rockwell B.
- Concerns are raised about the accuracy of converting between hardness scales, with some participants questioning the reliability of such conversions.
- One participant references a source recommending limited use of Rockwell testing for aluminum, suggesting that Vickers or other methods may be better for obtaining convertible hardness values.
- Another participant asserts that Rockwell B is a better option for measuring aluminum alloys.
Participants express differing opinions on the suitability of Rockwell B versus Rockwell E for measuring aluminum alloys, with no consensus reached on which scale is definitively better.
Participants highlight various assumptions regarding specimen thickness and indentation penetration, as well as the limitations of hardness testing methods for aluminum alloys.
