Ambiguous Problem Statement on Determining Speed of Aircraft
13 replies · 3K views · last reply
vcsharp2003
An aircraft is flying at a height of 3400 m above the ground. If the angle subtended at a ground observation point by the aircraft positions 10.0 s apart is
30 degrees. What is the speed of the aircraft?
s=vt, where s is the distance travelled at a speed of v in time t
When I attempted this problem, I came up with two different solutions and answers, and both seem correct to me. However, the answer obtained by the first method is correct according to the book.
The methods I used are as in screenshots below.
Isn't the problem statement ambiguous, or maybe I am missing something?
In diagrams below, point ##G## is the observation point on the ground, ##P_1## is the initial observed position of the aircraft and ##P_2## is the final observed position of the aircraft.
Handwritten diagram of an aircraft observed from ground point G: positions P1 and P2 are 100 apart on a horizontal line, with a 15 degree angle at G, sides 3400 and 15, and working tan 15 = 5v / 3400 giving v = 182.2 m/s.
Handwritten diagram of a right triangle with ground point G at the bottom, aircraft positions P1 and P2 on a horizontal line at top, and vertical height 3400 m. Labels: 10v between P1 and P2, angle 30 degrees at G. Below are the equations tan 30° = 10v/3400, 1/√3 = 10v/3400, v = 196.3 m/s.
The relative position of the observer isn't given, so you're right. Note that there's more possibiliites, if you don't assume the aircraft's path is directly overhead the observer.
By more possibilites, you mean the situation where the vertical line from ##G## going up does not intersect the line ##P_1P_2##, but intersects the extended line from ##P_1P_2##.
vcsharp2003 said:
By more possibilites, you mean the situation where the vertical line from ##G## going up does not intersect the line ##P_1P_2##, but it intersects the extended line from ##P_1P_2##.
As well as the two most reasonable possibilities - the observer's position being directly under the aircraft's path at either the start(/finish) or midpoint of the observation - it could well be 100 miles away.
I am curious whether there is a Physics book for high school students that is known for having an accurate list of questions/problems, and not ambiguous questions/problems. Maybe there is no such book in the whole world.
Ambiguous questions/problems discourages a student from studying Physics.
If there was, we wouldn't hear about it o0)
It's sad that no one in this world can come up with an accurate list of questions/problems in high school Physics.
Indeed. In addition, the problem does not state the vertical intersects the pathline of the aircraft.
Or even that the craft is flying in a straight line.
But not surprising. Unambiguous problems are a dime a dozen. There are lots of them. We tend not to notice them. It is the ambiguous or otherwise bad ones that you remember and complain about.
Since complaints about textbooks produce no useful relief for the complainer, we develop coping strategies. Strategies that may be useful in the real world where the problems with problems get much worse. [In the real world, they don't give you the information you need. The information they do give you may be incorrect. The problem they give you may not be the problem you need to solve. And a solution may not even exist].
Finally I found out that this problem is really ambiguous. I saw many solutions out there, on YouTube and on Google, and all of them assumed that the observation point is midway between the airplane path. Such problems should not be included in such a reliable book ! How can I get it removed?
What book are you talking about? Removed from where?
From what I can Google up, it is from the 11th grade CBSE question bank in India. I did not find an authoritative free-to-view copy.
Thanks. I wonder whether the original problem was accompanied by a diagram and the OP got a copy without it. A similar PF problem here does not suffer from ambiguity.
