What Is the Amplitude 3cm from an Antinode in SHM?
The discussion revolves around calculating the amplitude of a standing wave at a specific point, 3.0 cm from an antinode. The wavelength is determined to be 30 cm, and the frequency is calculated as approximately 13.333 Hz, leading to a wave speed of 4 m/s. Participants clarify that the amplitude at any point can be expressed using the equation y(x,t) = A sin(kx) sin(ωt), where the maximum value of sin(ωt) is 1. The key focus is on evaluating Asin(kx) at the specified distance from the antinode to find the amplitude. The conversation emphasizes understanding the standing wave equation and its application to the problem.
Ginerva123
Adjacent antinodes of a standing wave on a string are a distance 15.0cm apart. A particle at an antinode oscillates in simple harmonic motion with amplitude 0.850cm and period 0.0750s. The string lies along the +x - axis and is fixed at x=0.
At time t=0, all points on the string are at their minimum displacement.
Find the amplitude at a point a distance 3.0cm to the right of an antinode.
d^y(x,t) /dx^2 = 1/v^2 . d^2y(x,t)/(dt^2)
wavlength is 2 x 15 cm = .30m
f is 1/T = 13.333 Hz
so v = 4 m/s, v^2 = 16 and 1/v^2 is 0.0625
However, I' having trouble getting the second derivative of the wave equation using the point 3.0 cm to the right of the antinode.
What is the equation of a standing wave?
why are you trying to get the second derivative?
y(x,t)=(Asinkx)sinwt
I thought the second derivative wrt x was equal to the second derivative wrt t by the inverse of v squared. Or maybe not.
Yes, that's the right equation.
I still don't understand... why do you need the second derivative with respect to x, or with respect to time? you need the amplitude at a certain x value right?
you've got the equation of the standing wave.
The amplitude at any x value is simply Asinkx... because the maximum value that sinwt takes over time is 1... ie amplitude at x is Asinkx(1) = Asinkx.
you have A. you can get k ... You need the amplitude at a point 0.03m to the right of an anti-node... so just choose any anti-node... you've got the wavelength = 0.30m. where is the first anti-node?
what do you get for Asinkx, where x = 0.03 + position of anti-node ?
42K
  • · Replies 31 ·
