An equation for an algebra word problem
10 replies · 3K views
mech-eng
Suppose that b is 20% more than a, c is 25% more than b, and d is k% less than c. Find k such that a=d
a=d; b=1.2a; c=1.25b=1.5a
1. a=##\frac{c}{15 }##=d=##\frac{100c-k}{100}##
2. By multiplication of extremes and means we get 100c=150c-15.k
3. 50c=1.5k
4. Again simplifying k=33.3c
I have tried above solution but I think something is incorrect because k should be a number not a ratio in terms of c.
I don't latex well enough and it seems that step 1 is not seeming properly, too small symbols.
Source: Algebra and Trigonometry by Keedy Bittinger.
Thank you.
3. 50c=1.5k
Thank you.
You have a typo and an error in multi-equation #1.
For one, ##\ \displaystyle a=\frac{c}{1.5} \ ##. (Missed the decimal point.)
More importantly the last part is in error.
##\ \displaystyle \frac{100c-k}{100} \ ##​
is incorrect. ##\ k\ ## must also multiply ##\ c\ ##.
But if ##d## is ##k%## less than ##c##, does not this mean ##\frac{c}-k}{100} ## and isn't it ##\frac{100c-k}{100}##?
And would you please explain why percent sign not appear in this code?
Thank you.
3. 50c=1.5k
Thank you.
You need
$$d =\left( 1 - \frac{k}{100} \right) c$$
$$d =\left( 1 - \frac{k}{100} \right) c$$=##\frac{c}{1.5}##
##50c=15ck##
and k=3.333
Would you please write above in the proper latex form?
Thank you.
@mech-eng, I suggest you check your answer of ##k = 3.333\%## against your initial set of equations ##a=d; b=1.2a; c=1.25b##.
Also, although percentages proper are expressed as ##x/100##, it's easier & faster during calculation to assume 1 = 100%; thus instead of $$d = \left(1 - \frac{k}{100}\right) c$$ you can work more simply with ##d = (1 - k)c##. For that matter you can substitute a temporary value for that expression and do the subtraction later on.
##50c=15ck##
and k=3.333
Thank you.
That looks proper to me.
Mathematically, it's equivalent to
##\ \displaystyle d = \left(\frac{100-k}{100}\right) c ##
I think the OP was referring to the part of his comment that wasn't already formatted in LaTeX.
##\ \displaystyle d = \left(\frac{100-k}{100}\right) c=\frac c {15} ##
I added the right side but is it proper. I didn't used symbols such as \left and \right.
The following is what I added there. But it is not the same when it is on the right side. Would you please explain this?
## \frac c {15}##
Thank you.
## \frac c {15}##
Thank you.
Proper in what way?
You dropped the decimal point from 1.5 again, otherwise, it looks right math-wise .
By the way: for % symbol in LaTeX, use \ suffix as in \%.
## 7\% ## or ##k\%##
SammyS said:
Proper in what way?
Sorry. Question is solved. But look the Latex. Their size of the c/15 parts are different.
Thank you.
