An issue with the vector model of spin and its operators
The discussion revolves around the vector model of spin and its operators, focusing on the mathematical representations and interpretations of angular momentum in quantum mechanics. Participants explore the implications of the model, the behavior of spin operators, and the relationship between quantum mechanics and number theory.
  • One participant expresses confusion regarding the relationship between the vector model of spin and the definitions of the spin operators, particularly the ladder operators S+ and S-.
  • Another participant emphasizes that the vector model is a simplification and that angular momentum in quantum mechanics is not accurately represented as precessing vectors.
  • Some participants note that S+ and S- are stepping operators that change the value of m, rather than being treated as magnitudes.
  • There is a discussion about the quantization of Sx and Sy, with some participants suggesting that they could take on continuous values, while others argue they can only take integer or half-integer values.
  • A participant raises a question about the probability of measuring Sx given a determined Sz, seeking a formula for these probabilities.
  • Another participant attempts to connect the behavior of spin operators to a root system related to prime number distribution and the statistical properties of the zeta function.
  • Visual aids are shared, including models of spin states and numerical observations related to spin 5/2, prompting further exploration of the connections between these concepts.
Participants express differing views on the validity and interpretation of the vector model of spin, with no consensus reached on the quantization of Sx and Sy or the implications of the ladder operators. The discussion remains unresolved regarding the proper understanding of these concepts.
Participants acknowledge that the definitions and interpretations of spin operators depend on the context of quantum mechanics, and there are limitations in reconciling classical visualizations with quantum behavior. The discussion also highlights the complexity of relating mathematical models to physical phenomena.
This discussion may be of interest to those studying quantum mechanics, particularly in relation to angular momentum, spin, and the mathematical frameworks used to describe these concepts. It may also engage readers interested in the intersections of physics and number theory.
JeremyEbert
I can't seem to reconcile a part of the vector model of spin and some of its operators.
to quote wiki just above the "Bohr model" section:
http://en.wikipedia.org/wiki/Vector_model_of_the_atom#Mathematical_background_of_angular_momenta
"2.The magnitude of the vectors must be constant (for a specified state corresponding to the quantum number),
so the two indeterminate components of each of the vectors must be confined to a circle,
in such a way that the measurable and un-measurable components (at an instant of time)
allow the magnitudes to be constructed correctly, for all possible indeterminate components."
I would assume pythagorean theorem holds true and "the two indeterminate components (S_x & S_y)
of each of the vectors must be confined to a circle" of radius r:
magnitude = sqrt(s(s+1))
r = sqrt(s(s+1) - m^2)
however the operators are defined as:
S+ = sqrt(s(s+1) - m(m+1))
S- = sqrt(s(s+1) - m(m-1))
http://en.wikipedia.org/wiki/Spin_(physics)#Spin_operator
http://en.wikipedia.org/wiki/Anti-symmetric_operator#Spin
I must be missing something obvious. Please help.
A visual of spin 5/2 with some notes:
http://dl.dropbox.com/u/13155084/SPIN/SPIN-5-2-ladder-crop.png
Jeremy, It's unusual to see someone taking the vector model seriously - like driving a model T! :smile:
Be sure to understand that its only a model. In quantum mechanics angular momentum is not really represented this way, as precessing vectors.
If you look more closely at the definitions of S+ and S-, you'll see that they are stepping operators, that is they act to change the value of m up or down by one:
S+ |m> = √(s(s+1) - m(m+1)) |m+1>
S- |m> = √(s(s+1) - m(m-1)) |m-1>
so you can't just treat them as magnitudes.
Thanks Bill for you insight.
I am very new to this vector/spinor model, hence my unusual view.
I have heard that there is some controversy about all these
quantum and non-quantum visualizations of spin from Stan Sykora. He maintains the
high-resolution NMR spectra simulation dll in Mnova software and added some comments on
http://oeis.org/A003991 that peaked my interest on the subject.
I am trying to fully understand the concept of these spin operators because they are
eerily close to a root system I've been working on involving prime number distribution.
We already know a connection between number theory and quantum mechanics comes from
the discovery that the spacing's between consecutive zeros of the zeta function also appear to
behave statistically like the spacing's between consecutive eigenvalue's of large random matrices
which physicists use to obtain estimates of the average spacing between consecutive energy levels
of heavy atomic nuclei and other complex quantum systems.
So these ladder operators act to change the value of m up or down by one essentially changing the
observed value on the Z axis. Is it not correct to say that once S_z is observed, the un-measurable components
must lie somewhere along a circle of radius sqrt(s(s+1) - m^2)?
Jeremy, In the vector model, Sx and Sy could take on any continuous value along the circumference of a circle. The modern viewpoint is different - Sx and Sy (and any other spin projection) can only take integer or half-integer values. They can't be measured simultaneously, and so for a state in which Sz has been determined there will be some probability that Sx takes on each of its allowed discrete values.
Bill,
Thank you again. I assumed the values of Sx and Sy would be quantized as well. It seems logical seeing as the Z axis is actually an arbitrary direction usually determined by an external magnetic field. Sz is just used for convention, we could substitute Sx and Sy just as easily. Is there a formula for the probability of these other allowed discrete values?
Also, I still can't understand the ladder operators fully. They have been described as the relative intensities of the states with the equivalence S+ = Sx + i Sy and S- = Sx - i Sy, but the geometry doesn't seem to fit with the eigenvalues. Can you shed some light on this for me?
Bill,
If you think of the possible spin states as a function of the magnitude of spin then:
|S| = magitude
S+-=|x +- iy| = magnitude
applying the ladder opperators on the S_x states
one could come up with something like this model.
Notice the X-axis:
https://dl.dropbox.com/u/13155084/SPIN/SPIN-5-2-ladder%20XYZ.png
One link to the fact that you cannot observe the other projections is because
they do not fall on integer or half-integer values.
Is this a proper view of the ladder operators of the un-observable states?
JeremyEbert said:
Bill,
|S| = magitude
Notice the X-axis:
Bill,
Here is a 3D model of possible S_x and S_y states based upon the ladder operators.
You will need the Flash plugin to view. This runs through all Spin states up to s=75/2.
http://dl.dropbox.com/u/13155084/SPIN/index.html
Can't say as I understand your Flash model, but it sure does look cool, Jeremy. Feel free to explain it a bit more. Also, since you mentioned spin 5/2...
... here is a purely numerological observation that may or may not be of interest to you in relation to Stan Sykora's comments here at http://oeis.org/A003991 (the ones that piqued your interest):
[itex]S[/itex]=[itex]\frac{\hbar}{2}[/itex][itex]\sqrt{n(n+2)}[/itex] = [itex]\frac{\hbar}{2}[/itex][itex]\sqrt{5(5+2)}[/itex] == [itex]\frac{\hbar}{2}[/itex][itex]\sqrt{5 + 8 + 9 + 8 + 5}[/itex] = [itex]\frac{\hbar}{2}[/itex][itex]\sqrt{35}[/itex] for n = 5
In other words, for the special case of n = 5, then 35 is tetrahedral as per Sykora's example (sum of relative intensities of Spin 5/2 transition states) and also one less than a square, meaning that it follows form n(n + 2) as per the above formula for spin. The maths work out in this instance because any tetrahedral number is equal to the product of 3 consecutive integers divided by 6. Therefore, 5*6*7/6 = 35, the fifth tetrahedral number, and because the 6's cancel it is also one less than a square (=5*7).
- AC
  • · Replies 59 ·
