Add DC & AC Voltages: Learn How to Do It!
The discussion focuses on the possibility of adding AC and DC voltages using op-amps. Participants clarify that while it is feasible to add a DC voltage to an AC waveform, the output will shift the entire waveform vertically. The original poster seeks a symmetrical output of 7V peak and -7V peak, which leads to discussions about the roles of amplifiers and attenuators in achieving this. It is noted that amplifiers increase signal strength, while attenuators reduce it, and both can manipulate waveforms. Ultimately, the conversation concludes with a clearer understanding of the difference between amplification and waveform shifting.
kiamzattu
Hi
I've learned about voltage adder circuits using op-amp that add two or more DC voltages.
But is it possible to add AC voltage with a DC voltage? What i mean is can we add (for eg 2V DC with a AC of 5v peak value,50hz) so that the output is again AC with peak of 7V and frequency is 50hz
If so How?
That would be more considered an amplifier. A circuit can be designed that uses a DC control voltage to control the gain of an amplifier.
No, I don't think he's talking about an amplifier. Is this what you mean? The AC has peaks of +5V and -5V and you want to add 2V DC to get an output of +7Vpk and -3Vpk?
What do you think you'd get if you added them exactly the same way you added two DC voltages?
as long as you don't "hit the rails" with your summed signal, and the frequency is within the limits of your circuit, the opamp doesn't really care if it's AC or DC or any combination.
@Averagesupernova
No I'm not talking about amplifier.
@skeptic2
Yeah you got it right. But just a small variation. I don't want the output to be 7V and -3V, instead it should be 7Vpeak and -7Vpeak. Is that possible? because it is a sinusoidal signal and should be symmetrical.
anbullet said:
Hi
If so How?
If the OP and only add DC voltages it would be pretty useless. The OP Amp will of course have band width limitations and range limitations.
anbullet said:
@Averagesupernova
@skeptic2
Then you are talking about an amplifier. You're multiplying the original signal by a factor of 1.4.
anbullet said:
@Averagesupernova
@skeptic2
Depends on the OP amp and what voltage you connected across the power terminals. What is the application. If you are doing signal processing you might want to use an instrumentation amplifier, if you are doing control systems you might want to use a power amplifier. Power amplifiers are often based on, on and off switching.
Oh!. Now i get it. Thank you Skeptic2.
@John Creighto
The application is i'll be having a DC voltage and 2 sine waves which are 180 degrees out of phase. Now I'm required to add the DC voltage to one of them and subtract it with the other sine wave. Just like an amplifier of gain 1.4 goes the addition part,can an attenuator do the subtraction part? I don't know what an attenuator is or how it works. its my friend's idea.
why don't you start by writing out the equation(s) you want to implement?
Both amplifiers and attenuators work like multipliers. Amplifiers usually have a gain of more than one, attenuators have gains of less than one.
When you add a DC voltage to an AC waveform you shift the whole waveform up such as I posted above. It's exactly the same as adding that DC voltage to every point on the waveform. Subtraction would be the same but it shifts the waveform down.
Thank u everyone. Now i got a clear idea of the difference between amplification and shifting the waveform. I'll be needing only the amplification part.
