What hardware is needed for analyzing sound signals?
To analyze sound signals effectively, a good quality microphone is essential, as it significantly impacts the accuracy of recordings. A typical PC with a decent sound card can handle basic analysis, while various software options, many of which are free, can facilitate spectral and time plot analysis. Smartphones can be used for basic sound analysis, but a better microphone setup is recommended for more precise work. The discussion emphasizes that investing in high-quality recording equipment is crucial for obtaining accurate sound samples. Overall, a combination of quality hardware and accessible software is key for sound signal analysis.
fog37
Hello everyone,
I am interested in analyzing sounds (both spectral plots and time plot). What type of hardware would I need? There are a lot of free softwares online...
Are there educational hardware tools that are not too expensive?
thanks!
fog37 said:
Hello everyone,
thanks!
Could you say more about the sounds? What kind of analysis exactly are you wanting to perform? What is the application?
You can use a smartphone for basic analysis, but you would need a better microphone setup for some situations. What equipment and software packages have you looked into so far?
Likes sophiecentaur
For sound - a typical PC should do fine, if you have a good digital recording or sound card to record with. Use various combos of : open source, FFT, spectral analyzer, oscilloscope - etc...
There is no single list - too many variables.
Likes sophiecentaur
I guess a good microphone would be the right type of hardware and then I can use some software for the analysis...
Typically (and the mechanical engineers will hate me for this) the electrical systems are probably 100x more accurate than the mechanical, and software, 100 to 1000 or more times more accurate than electrical.
If you want accurate sound samples from the real world, spend at least 90% of your money on the microphone. ( IMO - conversely for reproduction -- spend the same ratio on your speakers... headphones are a little different, too much hype!). 20 years ago a 44kHz sample was hard to come by, but today that is child's play.
So, a really good microphone into an average sound card - is far better than a cheap mic into a great sound card.
Software today is practically free, one guy wants a good tool and gives it away, then the cost goes to zero - all of the others needs something physical.
the ffplay.c source from SDL-1.2 has a approx of FFT and little options but best option to visualize acoustics from hardware that being said am xbox controller is my preference and I have the source for output as well on my website Atmel-uController Repurposed
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
