Analysislimsup(inf) |sinn|^1/n = ? it`s not easy
  • Context: Graduate
  • Thread starter Thread starter omyojj
The limit of the sequence a_n = |sin n|^1/n does not converge, with limsup a_n equating to 1 and liminf a_n approaching 0. The discussion emphasizes the use of the equidistribution theorem to demonstrate that for any interval [a, b] within [0, 1], there are infinitely many integers n such that a < |sin n| < b. Participants suggest employing Diophantine approximation and Hurwitz's irrational number theorem to analyze the behavior of |sin n| and its implications on the limits.
  • Understanding of limit superior and limit inferior in sequences
  • Familiarity with the equidistribution theorem
  • Knowledge of L'Hôpital's Rule for evaluating limits
  • Basic concepts of Diophantine approximation
  • Research the equidistribution theorem and its applications in number theory
  • Study L'Hôpital's Rule in depth, focusing on its use in indeterminate forms
  • Explore Hurwitz's irrational number theorem and its implications for sequences
  • Investigate the properties of bounded sequences in the affinely extended real number system
Mathematicians, students studying real analysis, and anyone interested in the behavior of trigonometric sequences and their limits.
omyojj
Hi,all
My goal here is to show that the limit of a sequence a_n = |sin n|^1/n
i.e. lim _ |sin n |^1/n does not exist..(it does?)
is it possible to show that 1. limsup a_n = 1
2. liminf a_n = 0 (right??I`m not sure..)
Help me doing this job..
I think that it is more difficult to prove the latter..
one thing that obvious is that limsup |sinn|=1, liminf|sinn|=0..; )
it may be helpful using the equidistribution theorem..
(the sequence {1,2,3,...} is equidistributed mod 2π, quoted from the Wikipedia limsup)
then we can argue that for any 0<=a<b<=1 there are infinitely many n
such that a<|sin n|<b, and then we can proceed by using the def. of the limsup..
anyway..give me some hint..or solution..T.T
Graph the function f(x) = |sin(x)|1/x. It's got a pretty neat graph, and also you'll see that as x goes to infinity, f(x) does indeed appear to converge to a limit. So to solve your problem, consider the sequence log(an), make a simplifying comparison, and keep l'Hôpital's Rule in mind.
that seems to be right on the graph..thx..
f=|sinx|^1/x is close to 1 on the left for sufficiently large x..(but it does have inf. many zeros at integral multiples of Pi)...
but if there exists n that is in the δ neigborhood of m*Pi(m integer)...
such that |sinn|^1/n may not exceed 1-ε..
and the set of numbers satisfying this condition could be infinite...I don`t know..
If you are right..that it converges to 1..
hence limsup a_=1 then possible to show that liminf a_n = 1?
and if the lim exists..lim log(a_n) also exists..
To evaluate lim_log a_n = lim_1/x * log[|sinx|]
(x)` = 1 as x->inf.
but (log[|sinx|])` = |sinx|`/|sinx| -> ? x-> inf ??
clearly the limit does not exist...
Either way the limsup is 1. Who cares if there are a lot of 0s? There are also a lot of times when it will be very close to 1. A more interesting question is whether the liminf is 0 if n is an integer...
the hint would be to use a Diophantine approximation result to see how close |sin(n)| gets to 0 and how often. try Hurwitz' irrational number theorem (you can google this).
surely..I wonder whether the liminf a_n =? 0 or 1? or something..
(If the terms in the sequence are real numbers, the limit superior and limit inferior always exist in the affinely extended real number system..this seq. is bounded since 0<a_n<1 for all n..so 0<=limsup, liminf<=1 )
to be sure, a_n is a inf. seq. of real numbers..n is integer..
To prove liminf a_n = 0..How about this way..
Fix ε, suppose that there are finite set of integers such that |sin n_k| < ε^n_k
{n_k} = {n_1, n_2, ..., n_N}
is there any contradiction which leads to the equipartition thm..or sth..?
Again, be careful as a_n = |sin n|^(1/n) is never 0 for any positive integer value of n. For positive integers n, |sin n| is strictly between 0 and 1. This seems silly to point out, but better to be safe than sorry: in your graph, your domain should be restricted to the integers, and not reals. Otherwise you'll see infinitely many zeros.
No, the liminf isn't 0. I essentially told you how to compute the limit, did you try that?
(x)` = 1 as x->inf.
You can only apply L'Hopital's rule if you have in indeterminate form.
