Analytic Function Theorem: A Continuously Differentiable f(z)
  • Context: Graduate
  • Thread starter Thread starter Dragonfall
    Function
The discussion revolves around the definitions and properties of analytic functions, particularly focusing on the relationship between continuous differentiability and analyticity in the context of complex functions. Participants explore different definitions, theorems, and potential circularities in these concepts.
  • Some participants propose that a continuously differentiable function f(z) is analytic if and only if the differential f(z)dz is closed.
  • Others argue that an analytic function can also be defined as one that is locally represented by a convergent power series.
  • A participant notes that different texts may have varying definitions for the same mathematical object or property, suggesting that definitions can sometimes be results in different contexts.
  • One participant expresses concern about circularity in definitions, stating that the theorem implies a continuously differentiable function is analytic, which seems to restate the definition rather than provide clarity.
  • Another participant highlights the distinction between "continuously differentiable" and "complex differentiable," emphasizing the need to check definitions in the relevant text.
  • It is mentioned that a complex analytic function is smooth, meaning all derivatives are continuous, while "continuously differentiable" typically refers to the continuity of the first derivative only.
Participants do not reach a consensus on whether continuously differentiable functions are equivalent to analytic functions, and there is ongoing debate regarding definitions and implications of these terms.
Participants note potential circularity in definitions and the importance of context in understanding the terms used in different texts. There is also a distinction made between types of differentiability that may not be universally defined.
Dragonfall
A theorem states:
A continuously differentiable function f(z) is analytic iff the differential f(z)dz is closed.
Isn't continuously differentiable the DEFINITION of analytic?
But nevertheless it must be equivalent to "continuously differentiable". This theorem seems to say that "an analytic function is analytic iff the differential fdz is closed".
Different texts my have different definitions of the same object or property. A definition in one text can be a result in another.
The definition given in my text is "a function f(z) is analytic on the open set U if f(z) is complex differentiable at each point of U and the complex derivative f'(z) is continuous on U."
A while later came the theorem "a continuously differentiable function f(z) on a domain D is analytic iff the differential f(z)dz is closed."
I see circularity here.
(We're talking about complex functions here)
What does the proof say?
"Left as exercise."
"Continuously differentiable" is not the same as "complex differentiable," as far as I know. Make sure you've checked how the book defines those terms, and what sort of function you're looking at.
If a function is complex analytic, then it is smooth (ie ANY derivative is continuous, not just the first one). Generally "continuously differentiable" only means the first derivative is continuous (but maybe your book is different). If a function is real-analytic, the usual definition is that the Taylor series at any point converges to the function in a neighborhood of that point, or something like that.
