Analytical solution to the diffusion equation with variable diffusivity
An analytical solution to the 1D diffusion equation with variable diffusivity κ(x) is being sought. The equation presented is ∂_t u(x,t) = ∂_x[κ(x) ∂_x u(x,t)], and attempts to use separation of variables have proven unsuccessful due to the complexity of the variable diffusivity. The discussion suggests that while separation of variables typically works, the specific form of κ(x) complicates the process. A potential approach mentioned is the use of Green's functions, which may provide a pathway to a solution. Overall, the challenge lies in the difficulty of solving the resulting ordinary differential equation for general forms of κ.
kezman2000
Hi, I'm trying to find an analytical solution (if one exists) to the 1d diffusion equation with variable diffusivity κ(x);
<br /> \partial_t u(x,t) = \partial_x[\kappa(x) \partial_x u(x,t)]<br />
Could someone point me in the right direction to solve this if its possible to do so analytically. I've tried separation of variables after using the product rule to expand out the diffusive term but the equation isn't of the correct form.
Thanks for any advice,
Kieran
Greens function perhaps?
Why doesn't separation of variables work? u(x,t) = X(x) T(t), so
X\frac{dT}{dt} = T\frac{d}{dx}\left(\kappa(x) \frac{dX}{dx}\right).
You can divide through by XT and the left hand side will have only terms dependent on t and the right hand side will have only terms dependent on x, so both sides are some constant, k. Solving the x ordinary differential equation for general \kappa may be tricky, but separation of variables otherwise works.
  • · Replies 0 ·
