Analyze this opamp active filter circuit
5 replies · 2K views · last reply
ace130
Hello, so this the circuit of an IdeaI OPAMP.
Circuit schematic of an op-amp active filter with input e(t) and output s(t), containing two capacitors labelled C, two resistors labelled R, and a non-inverting op-amp configuration.
The Question is to find the function Vs/Ve .
I tried to make some sum ups to simplify it but I still unable to find a solution, so I tried to NOT sum up any component and found this:
E-S=iZ+i2(Z+R)
E=iZ+i3R
S=i2R
so the idea is to find E=f(i2) , This is the final Result but I'm not sure if it's correct :
Handwritten fraction with numerator Zc above a horizontal line and denominator 2R + R^2 + Zc^2 below it.
  • Circuit schematic of an op-amp active filter with input e(t) and output s(t), containing two capacitors labelled C, two resistors labelled R, and a non-inverting op-amp configuration.
  • Handwritten fraction with numerator Zc above a horizontal line and denominator 2R + R^2 + Zc^2 below it.
E-S=iZ+i2(Z+R)
E=iZ+i3R
S=i2R
I'm not quite sure what you are doing with your equations, but are you familiar with how to solve circuit problems using the Kirchhoff Current Law (KCL) equations? I would write the KCL equations for the two nodes in the middle (the - input of the opamp and the middle connection point between the 3 capacitors), and solve those simultaneous equations for the gain of the circuit s(t)/e(t).
Also, are you supposed to be solving this with phasors or differential equations?
Yes i know the KCL , also this should be solved in complex .
I don't know if I should sum up those Rs and Cs or just write KCL that will take more time
I don't know of a technique to "sum up" the Rs and Cs, but there may be one. Why not do it both ways to check your answer?
Can you show us the two KCL equations that I mentioned? Then show how you would solve them simultaneously...
this is the KCL and loops
Handwritten analysis of an op-amp circuit: a schematic with input Ve, impedances Zc and Z, resistor R, output Vs, and loop currents i1 to i4, followed by numbered loop and KCL equations.
and this is the final result:
Handwritten derivation of a transfer function Vs/Ve = R divided by (Zc - R) + 1/Zc + 2Zc^2/R + Zc, with intermediate loop equations for Ve and i1 shown above.
Edit : the final line it should be Zc not 1/Zc .
  • Handwritten analysis of an op-amp circuit: a schematic with input Ve, impedances Zc and Z, resistor R, output Vs, and loop currents i1 to i4, followed by numbered loop and KCL equations.
  • Handwritten derivation of a transfer function Vs/Ve = R divided by (Zc - R) + 1/Zc + 2Zc^2/R + Zc, with intermediate loop equations for Ve and i1 shown above.
Your equation (2) is not right. It suffers from a sign convention error.
