Angle between vectors (2,1,-4) and (-3,0,1)
  • Thread starter Thread starter Yahaira.Reyes
    Physics Vector
7 replies · 30K views · last reply
Yahaira.Reyes
Let vectors [tex]\vec{A}[/tex]=(2,1,-4) [tex]\vec{B}[/tex]=(-3, 0, 1), and [tex]\vec{C}[/tex]= (-1, -1, 2) .
Calculate the following:
What is the angle[tex]\theta_{AB}[/tex] between [tex]\overline{A}[/tex] and [tex]\overline{B}[/tex] ?
[tex]\vec{A}[/tex] * [tex]\vec{B}[/tex]= magnitude of A * Magnitude of B * Cos[tex]\theta[/tex]
magnitide of X= [tex]\sqrt{a^{2}+b^{2}+C^{2}}[/tex]
magnitude of A= 4.58
Magnitude of B= 3.16
[tex]\theta[/tex]=arccos[( A * B)/ magnitude of A * magnitude of B)
I tried that but the incorrect answer. Maybe i did the arithmetic wrong. Please Help..
I can't tell you if you did the arithmetic wrong if you don't show your calculations...
Also, it seems you posted this problem in the forum 3 times. Please do not flood the forum with repeat posts.
sorry if i posted it three times. It is my first time using this program.
magnitude of a= [tex]\sqrt{2^{2}+ 1^{2}+ 4^{2}}[/tex]= 4.58
Magnitude of b= [tex]\sqrt{-3^{2}+ 1^{2}}[/tex]= 3.16
and the vector A * the Vector B gives me -10
OK, you calculations for the magnitudes are correct. Can you show me what you get for [tex]\theta[/tex] and the full calculation involved?
I ask because you have the correct formula, so I think the error is probably in your calculation somewhere.
a ha! i just saw my mistake! But i will show you my calculations that i just re-did
[tex]\theta[/tex][tex]_{AB}[/tex]= arccos[ -10/ (4.58* 3.16)]
= arccos(-10/ 14.47)
= 133.7
Thanks a lot!
= 133.7
Thanks a lot!
I can't tell you the number of times I begin to spend the time typing up a problem here, and then all of a sudden I figure out the answer to my question.
i know i couldn't believe it! I was so frustrated trying the problem out over and over. I lauphed so hard when i figured it out lolz... I thought it was such a hard problem, turned out pretty easy
