Fluxthroughme
- 71
- 0
The method I'm using in the image is the one that makes the most sense to me, but I've tried others and still cannot get at the stated answer, which is 2.65 rad/s^2
The discussion revolves around a problem involving angular acceleration caused by a mass over a pulley system. Participants are attempting to understand the relationships between linear and angular quantities, specifically how tension, mass, and acceleration interact in this context.
The discussion is active, with participants providing guidance on setting up equations and clarifying concepts. There is a focus on correcting assumptions and exploring the relationship between linear and angular accelerations. Some participants express confusion about the equations and the relationships involved, while others offer insights to help clarify these points.
Participants are working under the constraints of a homework problem, which may limit the information available. There is an emphasis on not making assumptions about tension and ensuring that all variables are properly defined in the equations.
Doc Al said:Do not assume that the tension in the rope equals the weight of the hanging mass. Set up two equations, one for the post and one for the hanging mass. Then you can solve for the acceleration.
Don't guess, solve! Call the tension T and set up your equations. That will be one of the unknowns. Luckily, you'll have two equations and two unknowns.Fluxthroughme said:Sorry, how do I go about that? If the tension in the string isn't 5g, I don't know how to do it.
Doc Al said:Don't guess, solve! Call the tension T and set up your equations. That will be one of the unknowns. Luckily, you'll have two equations and two unknowns.
Good! Since the mass falls, I would choose positive as down and let "a" stand for the magnitude of the acceleration.Fluxthroughme said:I'm not even guessing; I just don't know how to set up the equations. T - 5g = 5a, I think?
Doc Al said:Good! Since the mass falls, I would choose positive as down and let "a" stand for the magnitude of the acceleration.
Now write an equation for the post.
You already set up the equation for the post in your first post! Your mistake was assuming that the tension was equal to mg. Set the unknown tension equal to T and write out that equation.Fluxthroughme said:I'm not sure how I can be any more direct: I am 100% lost at the post. It's not for lack of thinking, I just don't know what the equation ought to be?
Doc Al said:You already set up the equation for the post in your first post! Your mistake was assuming that the tension was equal to mg. Set the unknown tension equal to T and write out that equation.
Yes, that's what I mean. Almost. It should be rF = I*alpha.Fluxthroughme said:If you mean [itex]rF=I/alpha[/itex], then isn't that a different acceleration to the acceleration for the block?
Doc Al said:Yes, that's what I mean. Almost. It should be rF = I*alpha.
Yes, one is an angular acceleration and the other is a linear acceleration. How are they related? (The rope is attached to the post.)
You need to fix the sign of "a" in your equation for the hanging mass.Fluxthroughme said:Well, regardless, I still get the wrong answer:
Doc Al said:You need to fix the sign of "a" in your equation for the hanging mass.
Write your equations. Tell me how alpha relates to "a".Fluxthroughme said:Which doing will give me 2.84 as the final answer, which is still incorrect? =/
Doc Al said:Write your equations. Tell me how alpha relates to "a".
Don't solve them, just write them.
(I solved it and got the correct answer, so we need to see where you are going wrong.)
How can an angular acceleration (in rad/s^2) be the same as a linear acceleration (in m/s^2)?Fluxthroughme said:I don't know how it relates it general, but at that instant, they are the same?
Doc Al said:How can an angular acceleration (in rad/s^2) be the same as a linear acceleration (in m/s^2)?
But they are related. Consider the point of attachment of the rope with the post. How does the linear acceleration of that point relate to the angular acceleration of the post?
You're almost there.
Now you've got it.Fluxthroughme said:Ok, [itex]a=r\alpha[/itex]
Solving from there is just basic algebra. Prior to googling, I had not seen this, nor thought about a concrete relationship between them, which must've been why I could not see how to do the problem. Thank you for putting up with me :P
You should be able to the the correct answer now.
