Annihilation and energy occurance
  • Level: Graduate
  • Thread starter Thread starter humsafar
    Annihilation Energy
22 replies · 6K views · last reply
humsafar
Can someone be precise and tell how much energy is released when annihilation occurs...let's say proton-antiproton(i.e in MeV),also is there some missing energy in it that is not detected(i.e difference between predicted and observed results in energy generation)
In general, annihilation ends up with two photons, each with the energy equivalent to the mass (E=mc2) of one of the particles involved.
I believe the total amount of energy released would be equal to the sum of the two particle masses/energy. An at rest proton and anti-proton would release 2 x 0.938 GeV/c2 in energy in the form of new particles. (Since 0.938 GeV/c2 is the rest mass of a proton.)
If you add energy into the particles before they annihilate, such as by accelerating them, they will release more energy.
drakkith said:
if you add energy into the particles before they annihilate, such as by accelerating them, they will release more energy.
why??
Yeah but can someone give numbers?(i.e in MeV how much more is detected)
Only if you give numbers for how much more energy is added in KE. The detected energy is equal to the sum of the mass energy plus the added KE.
Two or three, depending on the spins of the original particles. See http://en.wikipedia.org/wiki/Positronium#States".
What is KE exacly?
Ok Ok...but can anyone tell the quantity of energy we get during annihilation is "HOW MANY TIMES" that of fusion?
You really will need to be more specific than that. There are a lot of different fusion reactions, each one with a different yield.
For the proton-proton chain which dominates the fusion in our sun converts about 0.7% of the mass into energy. So proton-antiproton annihilation releases about 143 times more energy.
http://en.wikipedia.org/wiki/Proton-proton_chain
The number of photons can vary, with low numbers being more likely, and will depend on net angular momentum. If particle-anti-particle pair has angular momentum of 1, for example, at least 3 photons have to be emitted. (Odd number, 1 being forbidden.) Though, for most (all?) particles, the probability of the pair emitting a single photon first, and decaying to a 0 orbital momentum state before annihilation is greater.
Thanks for the numbers...but at the start of this thread I was looking for numbers in "Mega Electron Volts" and a comparison then,
the answer your demanding is dependent on the input variables, like anything else. KE is just one of the input, more would include the angle of interaction if it took place in a 3D model.
Few more questions,
1) What is the comparison of strong force to electromagnetism in a particle (let's say in proton), i.e how much is the strong force present as compared to em force (let's hypothetically assume releasing strong force creates 100 MeV energy, how much energy will be created releasing em force)?
The electromagnetic force is what holds together molecules, so "releasing em force" is a chemical reaction. There are many different chemical reactions, you need to specify which chemical reaction you are interested in and any relevant conditions.
The strong force is what holds together nuclei, so "releasing strong force" is a nuclear reaction. There are many different nuclear reactions, you need to specify which nuclear reaction you are interested in and any relevant conditions.
humsafar said:
Few more questions,
Fusion of Tritium and Deuterium releases about 17.6 MeV in energy, thanks to the strong nuclear force. This is thousands of times more energy than one reaction between oxygen and gasoline in an engine.
Can someone give links to easy to understand ebook on atomic structure focusing on QCD, Electromagnetism...?
And other processes if possible such as fusion, annihilation ...
Can someone describe the Weak force, I'm having troubles understanding its definition and what it does, please describe in detail but simple wordings if possible...
