Another le chatelier qsneed to make sure
  • Thread starter Thread starter angel_eyez
The equilibrium reaction 2CrO4(aq) + 2H+(aq) <--> Cr2O7(aq) + H2O will shift to the right upon the addition of dilute HCl to a K2CrO4 solution. This occurs because the HCl dissociates to release H+ ions, which react with CrO4^2- ions, driving the equilibrium towards the formation of Cr2O7^2-. The extent of this shift depends on the concentration of HCl relative to the existing reactants and products in the solution.
  • Understanding of chemical equilibrium principles
  • Knowledge of acid-base reactions
  • Familiarity with the concept of Le Chatelier's Principle
  • Basic knowledge of ionic dissociation in aqueous solutions
  • Research the application of Le Chatelier's Principle in various chemical reactions
  • Study the ionization process of strong acids like HCl in aqueous solutions
  • Learn about the properties and reactions of chromate and dichromate ions
  • Explore equilibrium constant calculations for acid-base reactions
Chemistry students, educators, and professionals interested in chemical equilibria, acid-base reactions, and the behavior of chromate and dichromate ions in solution.
angel_eyez
1. for the equilibrium reaction below predict what would happen if dilute HCl were added to the K2CrO4 solution?
2. 2CrO4(aq) + 2H+(aq) <--> Cr2O7(aq) + H2O
3. The reaction will shift to the right because the acid will donate a proton which will react with H+ to produce hydrogen gas so therefore the rxn has to shift to the right to use up HCl. i need to knwo if this is righhtt. THXN
Try writing the equation for the ionization of HCl.
BTW, H+ will not donate a proton to another H+ to form hydrogen...
H+ + H+ -----> H2++ ? (won't happen)
So there will b no change in the equation??
I guess it depends on how dilute the HCl is compared to the concentrations of the reactants and products. If the HCl did contribute significantly, the HCl would ionize to produce more H+, so the reaction would shift to the right to counteract the addition of reactants.
11K
25K
9K
