Concentric Pipe Air Ejection: Effects on Flow Mixing and Pressure
  • Thread starter Thread starter sid_galt
The discussion centers on the interaction of air flows from two concentric pipes, where the outer pipe ejects air at 10 atm and 1200K, while the inner pipe ejects air at 1 atm and 600K. The consensus indicates that the outer flow will exert backpressure on the inner flow, potentially preventing it from exiting into the common duct. Numerical simulations are recommended to analyze the inertia of both streams and predict flow behavior, as the mass flow rates are equal, making inertial differences negligible. The possibility of supersonic flow and its effects on pressure waves is also highlighted.
  • Understanding of fluid dynamics principles
  • Knowledge of pressure and temperature effects on gas flow
  • Familiarity with numerical simulation techniques
  • Basic concepts of supersonic flow and shock waves
  • Research numerical simulation tools for fluid dynamics, such as ANSYS Fluent or COMSOL Multiphysics
  • Study the principles of supersonic flow and shock wave formation
  • Learn about the effects of backpressure in fluid systems
  • Explore the impact of temperature gradients on gas flow behavior
Engineers, fluid dynamics researchers, and anyone involved in the design and analysis of pneumatic systems will benefit from this discussion.
sid_galt
There are two concentric pipes. The outer pipe is ejecting air at 10 atm and 1200K. The inner pipe is ejecting air at 1 atm and 600K.Mass flow rate is the same and the air is being ejected into a common duct. What will happen?
Will the the two flows mix together in the common duct producing a medium pressure and medium temperature or will the outer pipe exert backpressure on the inner one preventing the air from getting out?
What do you think happens?
I think the backpressure from the outer flow and the mixed flow will be too much to overcome.
Yes, but the 'mixed' flow will occur within the smaller pipe not in the common duct.
To my understanding the answer is not an easy one. It would depend on the inertia of both streams. Maybe to answer your question it would be needed a numerical simulation. If the velocity of the low pressurized stream is small enough, then it could be a backwards flow from the high pressurized stream because the first one wouldn't have the needed inertia to convect the flow downstream.
The mass flow rates of the outer and inner fluid are the same though so inertial differences are negligible.
Or perhaps supersonic flow again with a converging diverging nozzle shape of the inner pipe. Although I don't have much idea how that will play out as the speed of sound is different in both the flows. My best guess is that oblique shock will not occur as the velocity of sound in the outer flow is much higher than in inner flow (assuming the mach numbers in the inner flow are very low but above 1) but as the flow inside the inner pipe is still supersonic, the pressure waves won't travel upwards and the flow wouldn't be blocked.
I don't care the inertia difference. I am talking about absolute inertia of each stream. Numerical simulation is needed here.
18K
