Ant chemical trails and detectors Moved to Biology
The discussion revolves around the chemical trails left by ants, their sensory mechanisms for detecting these chemicals, and methods for removing these trails. Participants explore the biological and chemical aspects of ant behavior, as well as potential electronic detection methods. The conversation touches on both theoretical and practical applications, including pest control and the nature of ant communication.
  • Homework-related
  • Participants inquire about effective methods for removing ant chemical trails, with suggestions including soap and water, which some believe should work due to the susceptibility of biologically generated molecules.
  • There is a discussion on how ants' chemical sensors function, with some proposing that they operate similarly to human olfactory receptors, where molecular shape determines binding affinity.
  • One participant raises the question of whether ants utilize quantum mechanisms in their sense of smell, referencing theories related to human olfaction.
  • Another participant provides a detailed explanation of olfactory receptor neurons and their role in detecting odors, drawing parallels to human sensory processes.
  • There is a mention of Dr. Turin's theory regarding molecular vibrations and inelastic electron tunneling, questioning if similar mechanisms apply to ants.
  • Some participants express uncertainty about the existence of research specifically addressing the quantum aspects of ant olfaction, suggesting that the current understanding is limited.
  • A participant shares an observation of ants in their environment, seeking identification and advice on pest control methods, particularly for Carpenter ants.
  • Others contribute to the identification of the ants and discuss various pest control strategies, including the effectiveness of different chemical treatments.
Participants express a range of views on the mechanisms of ant olfaction and the effectiveness of various removal methods. There is no consensus on the quantum aspects of ant smell, and the discussion remains unresolved regarding the specifics of ant sensory biology and pest control strategies.
Limitations include the lack of definitive research on the quantum mechanisms in ant olfaction and the varying effectiveness of proposed pest control methods, which may depend on specific circumstances and ant species.
Individuals interested in entomology, pest control, chemical biology, and the sensory mechanisms of animals may find this discussion relevant.
Cobul
1. How do you remove ants chemical trails on the wall? Water and rug not enough?
2. What are the exact details of the ants incredible chemical sensors in their antenna? How can they able to tell the difference between a hydrocarbon with 25 carbon atoms versus 24 atoms?
3. Lastly, is there an electronic detector that can smell the chemical trails of ants?
References:
https://www.google.com/amp/s/www.wa...-crazy-refined-sense-of-smell/?outputType=amp
"These guys can smell almost any hydrocarbon we offered to them," Ray said. "Along with it, we also discovered not only did they have a very extensive olfactory system, they are also able to distinguish very well between very closely related [compounds]. They are able to tell the difference between a hydrocarbon with 25 carbon atoms versus 24 atoms."
Biology news on Phys.org
Soap and water should work fine if I had to guess. Most biologically generated molecules are fairly susceptible to soap and water.
Just like your nose does. The receptors function sort of like a lock while the the molecules being smelled function sort of like a key. Adding another atom onto a molecule typically makes it change shape and not fit into its 'lock' and so it either doesn't bind or doesn't bind very well.
By the way. I read somewhere humans may use quantum to smell (just google it).
Do ants use quantum too? Like the version of the human quantum smell?
Nature behaves according to laws which are best described by qauntum physics (except gravity, so far). So, one could say that everything 'uses quantum'.
See: https://repository.asu.edu/attachments/190173/content/Specialized%20odorant%20receptors_2017.pdf
Basically it's a beautiful example of neuro-biochemistry. The following (Olfactory receptor neurons) is a description of the process in the human nose but I believe it's very similar to how ants follow chem trails. I assume the olfactory receptors are receptors (proteins) on the dendrites of olfactory neurons located on ant antenna (this is the lock described above). The resulting action potential is the physiological manifestation of "detection" very similar to the way serotonin and other neuro-transmitters work in the human brain:
ORs (olfactory receptors), which are located on the membranes of the cilia have been classified as a complex type of ligand-gated metabotropic channels.[6] There are approximately 1000 different genes that code for the ORs, making them the largest gene family. An odorant will dissolve into the mucus of the olfactory epithelium and then bind to an OR. ORs can bind to a variety of odor molecules, with varying affinities. The difference in affinities causes differences in activation patterns resulting in unique odorant profiles.[7][8] The activated OR in turn activates the intracellular G-protein, GOLF (GNAL), adenylate cyclase and production of cyclic AMP (cAMP) opens ion channels in the cell membrane, resulting in an influx of sodium and calcium ions into the cell, and an efflux of chloride ions. This influx of positive ions and efflux of negative ions causes the neuron to depolarize, generating an action potential.
https://www.bbc.com/news/science-environment-21150046
I was referring to Dr. Turin specific theory.
"Molecules can be viewed as a collection of atoms on springs, so the atoms can move relative to one another. Energy of just the right frequency - a quantum - can cause the "springs" to vibrate, and in a 1996 paper in Chemical Senses Dr Turin said it was these vibrations that explained smell.
The mechanism, he added, was "inelastic electron tunnelling": in the presence of a specific "smelly" molecule, an electron within a smell receptor in your nose can "jump" - or tunnel - across it and dump a quantum of energy into one of the molecule's bonds - setting the "spring" vibrating."
Does ants use inelastic electron tunnelling in their smelling?
I do not know. So I did a search on both ArXiv and NIH - nothing returned a decent match.
So, when there is no research to help us to help you we are kind of stuck. So, let's just say we do not know, which is the most reasonable answer.
What you seem to be interested in - google scholar search 'Formicidae pheromones' - does result in the most numbers of `interesting papers. But not spot on the topic you want.
I think this just describes molecular bonding, which takes place when you smell as molecules in the air bond with receptors in your nose. The description here is very basic but good enough for the average layman.
I saw these ants in my parking near a small garden. It is about 0.3 inches in length. I didn't see any half inch. What kinds of ants are these? It seems to Carpenter ants but they were nowhere to be half inch and not near any wood. And they weren't attracted to Borax (won't drink them).
https://www.pestworld.org/news-hub/pest-articles/ants-101/
Cant identify it from any of the pictures in the site. Got any clue? Thank you.
What is your location? That's going to help significantly.
I already confirmed it was Carpenter Ants.
I spent many hours researching how to get rid of it. Whether to use Prallethrin, Delmathrin, Iminoprine, Cyberthrin, Ant dusts, Ant Granules, Finopril bait. Borax doesn't work.
Who has dealt with Carpenter Ants among you? How do you get rid of them? Fortunately, Our version is only 1/4" long. Who has seen 1 " long Carpenter Ants?
  • · Replies 19 ·
10K
24K
23K
  • · Replies 21 ·
  • · Replies 41 ·
9K
