Application of Cauchy's residue theorem
4 replies · 2K views
lyranger
Really need help for this one. Cheers!
Question: calculate function z/(1-cos z) integrated in ac ounterclockwise circular contour given by |z-2pi|= 1
Clearly the pole in the given contour is 2pi. But the problem is: if it's a simple pole, then apply formula
we have Residue=lim (z-2pi) * z/(1-cos z) where z->2pi. This limit does not exist.
So I reckon 2pi might be a higher order pole but this actually makes no sense and even if it's true,
there is a really nasty differentiation.
Any thoughts.?
Yes, please use LaTeX.
What you need is a Laurent expansion around the pole at [itex]z=2 \pi[/itex]. For your function
[tex]f(z)=\frac{z}{1-\cos z}[/tex]
you have
[tex]1-\cos z=\frac{(z-2 \pi)^2}{2}+\mathcal{O}[(z-2 \pi)^4].[/tex]
You need the single-order pole contribution. You can get this by either using the standard formula
[tex]\text{res}_{z \rightarrow 2 \pi} f(z)=\lim)_{z \rightarrow 2 \pi} \frac{\mathrm{d}}{\mathrm{d} z} (z-2 \pi)^2 f(z),[/tex]
which is a bit cumbersome here, or you use the series expansion of [itex]1-\cos z[/itex] as given above and use [itex]z=(z-2 \pi)+2 \pi[/itex] in the numerator.
sorry for not using LaTex, haven't used this forum in ages.
And thanks so much for the help! very smart move!
Correct me if I am wrong, the answer is 4i*pi?
