Application of Fermat's Little Theorem
6 replies · 2K views
Enharmonics
Find the remainder of ##4^{87}## in the division by ##17##.
Fermat's Little Theorem:
If ##p## is prime and ##a## is an integer not divisible by ##p##, then
##a^{p-1} \equiv 1 (\mod \space p)##
or equivalently,
##a^p \equiv a (\mod \space p)##
I began by directly applying the theorem, since ##p=17## is prime and doesn't divide ##a=4##:
##17|4^{17} - 4 \rightarrow 17|4(4^{16} - 1) \rightarrow 17|4^{16}-1##
By definition of the modulo, ##p|a-b \rightarrow a \equiv b (\mod \space p)## , so ##4^{16} \equiv 1 (\mod \space 17)##
Next I note that ##87 = 16 * 5 + 7##, so
##[4^{87}]_{17} = [4^{16*5 + 7}]_{17} = [4^{16*5}]_{17} * [4^7]_{17} = [4^{16}]^5_{17} * [4^7]_{17} = [1]^5_{17} * [4^7]_{17} = [1]_{17} * [4^7]_{17} = [4^7]_{17}##
Then I repeated the process from the beginning based on the result I just got:
##17|4^7 - 4 \rightarrow 17|4(4^6 - 1) \rightarrow 17|4^6-1##, where ##4^6 \equiv 1 (\mod \space 17)##
Since ##87 = 6 * 14 + 3##, I wrote
##[4^{87}]_{17} = [4^{6*14 + 3}]_{17} = [4^6]^{14}_{17} * [4^3]_{17} = [1]_{17} * [4^3]_{17} = [4^3]_{17}##
At this point it seems easy enough to note that ##4^3 = 64## and
##64 = 17*3 + 13##
So the remainder is 13... I think? Is this procedure correct?
Just in case it is, I actually tried repeating the process once more when I got ##[4^3]_{17}##, so that
##17|4^3 - 4 \rightarrow 17|4(4^2 - 1) \rightarrow 17|4^2 -1##
And, repeating the same procedure of rewriting the exponent, arrived at ##[4^{87}]_{17} = [4]_{17}##.
Of course, 4 doesn't yield a remainder of 13 when divided by 17, unlike ##4^7## and ##4^3##.
Naturally, it's easy enough to note that ## 4^2 -1 < 17##, so ##17## doesn't divide ##4^2 - 1##. I'm a little confused here, though... is it necessary for the term ##a^{p-1} - 1## to be larger than ##p## for the application of the theorem to work?
Hi Enharmonics! :oldsmile:
You were fine until you "repeated the process".
Unfortunately ##17|4^7-4## is not true.
Where did you get it from? It's not Fermat's little theorem.
Instead we have:
##[4^6]_{17}=[(4^3)^2]_{17}=[64^2]_{17}=[13^2]_{17}=[(-4)^2]_{17}=[16]_{17}=[-1]_{17}##
So we have ##4^6\equiv -1 \pmod{17}## and ##17|4^7+4##.
It's by accident that it still yields the correct remainder 13.
Instead we have:
I got ##17|4^7-4## from the fact given by re-applying the fact that ##p|a^p-a## (taken from Fermat's Little Theorem). I thought that since I found it by using the fact that ##17|4^{17} - 4##, it would be okay to use. I kinda suspected it wasn't okay, since it would be uncharacteristically easy and formulaic given the subject matter (Discrete Math), so imagine how excited I was when I actually got the right answer! (even though it turned out to be by accident)
I'm a bit lost now, though. If ##17|4^7-4## isn't valid, how come you start at ##[4^6]_{17}## when our last result was ##[4^87]_{17} = [4^7]_{17}##? Is it by using the fact that ##a^{p-1} = 1 (\mod \space p)##?
Also, how did you do these particular steps:
##... [64^2]_{17}=[13^2]_{17}=[(-4)^2]_{17}= ... ##
Is it just by using the Division Algorithm, i.e. ## 64 = 17*1 + 13##, ##13 = 17*1 + (-4)## ?
Finally, how do I use the final result ##4^6 = -1 (\mod \space 17)## and ##17|4^7 +4## to show that the remainder is 13?
Thanks.
... but that's not a re-application...
A reapplication is either ##7|4^7-4## or ##17|4^{17}-4##.
That's because the ##p## occurs twice and has to be the same!
Yes. It's the division algorithm.
Let's get back on track.
We have:
##[4^{87}]_{17} \equiv 4^{7} \equiv (4^3)^2\cdot 4 \equiv 64^2 \cdot 4 \equiv (-4)^2 \cdot 4 \equiv 64 \equiv 13 \pmod{17}##
Fermat's Little was not needed. 487=4*1643=4*(17-1)43. From the Binomial Theorem, all terms of (a-1)n divides by a, except the last term, which is (-1)n. So 1643=-1 mod 17. It is straightforward from here.
edit: I think it is the same as fresh's hint.
