Applying a substitution to a PDE
  • Thread starter Thread starter etotheipi
    Pde Substitution
4 replies · 2K views
etotheipi
Please see below
N/A
Problem: Consider the equation $$\frac{\partial v}{\partial t} = \frac{\partial^{2} v}{\partial x^2} + \frac{2v}{t+1}$$ where ##v(x,t)## is defined on ##0 \leq x \leq \pi## and is subject to the boundary conditions ##v(0,t) = 0##, ##v(\pi, t) = f(t)##, ##v(x,0) = h(x)## for some functions ##f(t)## and ##h(x)##. Using the substitution ##v=(t+1)^{2}u##, show that ##u## satisfies $$\frac{\partial u}{\partial t} = \frac{\partial^{2} u}{\partial x^2}$$ Attempt: I'm not sure if I'm doing the differentiation correctly. I did $$\frac{\partial v}{\partial t} = 2u(t+1)$$ $$\frac{\partial^{2} v}{\partial x^{2}} = \frac{\partial}{\partial x} \frac{\partial v}{\partial u} \frac{\partial u}{\partial x} = \frac{\partial}{\partial x} (t+1)^{2} \frac{\partial u}{\partial x} = (t+1)^{2} \frac{\partial^2 u}{\partial x ^2}$$ Plugging this in doesn't appear to give the result. My suspicion is that I was supposed to use the product rule for the first derivative, however I don't think that is right since I thought we were supposed to hold everything else constant during the differentiation? If I try this for the sake of it, I get $$\frac{\partial v}{\partial t} = 2u(t+1) + (t+1)^{2} \frac{\partial u}{\partial t}$$ $$\frac{\partial^{2} v}{\partial x^{2}} = \frac{\partial}{\partial x} \frac{\partial v}{\partial u} \frac{\partial u}{\partial x} = \frac{\partial}{\partial x} [(t+1)^{2} \frac{\partial u}{\partial x} + 2u(t+1)][\frac{\partial u}{\partial x}]$$ This seems even more wrong. So I wondered whether anyone could give me a pointer? Thanks!
etotheipi said:
Homework Statement:: Please see below
Relevant Equations:: N/A
The second partial differentiation you could have simply written down, as ##t## and ##x## are independent variables.
For the first one you need to treat ##u## as a function of ##x## and ##t##.
If you get stuck you should always write out functions with their arguments. In this case we have:
$$v(x, t) = (t+1)^2u(x, t)$$
Ah okay that works. Then I get
$$\frac{\partial v}{\partial t} = 2u(t+1) + (t+1)^{2}\frac{\partial u}{\partial t}$$ $$\frac{\partial^{2} v}{\partial x^{2}} = (t+1)^{2} \frac{\partial^{2} u}{\partial x^{2}}$$
and that checks out. The take away is that you only hold constant the variables which the one you're differentiating is a function of. The others you still have to treat with product rules etc.
Yeah, I might start doing this. It makes it a little clearer. Thanks!
I thought I'd write up the solution I got for completeness, using the technique of guessing ##u(x,t) = A(x)B(t)## and then setting both sides equal to ##-\lambda##. One side turns out to be a "radioactive decay" one and the other is a "SHM" one: $$\frac{dB}{dt} = -\lambda B \implies B = Ce^{- \lambda t}$$ $$\frac{d^{2}A}{dx^{2}} = -\lambda A \implies A = D\cos{(\sqrt{\lambda} x + \phi)}$$ So I get ##v(x,t) = E(t+1)^{2}e^{- \lambda t}\cos{(\sqrt{\lambda} x + \phi)}##, and I guess I also need to substitute in the boundary conditions, though this should be fine since I have three unknowns and three conditions.
There are a few warning signs, since the question says that I "may find it helpful to use the substitution ##u(x,t) = w(x,t) + \gamma x## for a suitably chosen constant ##\gamma##". I've no idea what this is supposed to be implying...
