Approximation in step 24 of FSU PHY5524 problem set
  • Thread starter foldylocks
    Approximation
5 replies · 2K views · last reply
foldylocks
I am trying to follow the reasoning of the last problem in the set linked below. I can't figure out what approximation they used in step 24. Thanks.
http://www.physics.fsu.edu/courses/spring08/phy5524/sol1.pdf
It looks like it might be an approximation based on a geometric series, but there is no summation.
They're using the approximation ##\frac 1 {1-x} \approx 1+x##, or even more appropriately, ##1+x \approx \frac 1 {1-x}## where ##x=\frac {N-1}2 \frac {v_0} V##.
There is a summation at step 20.
The approximation comes in at 21-22
But you want to know how you go from $$\frac{P}{k_BT}\simeq \frac{1}{V-(N-1)v_0/2}$$ to $$\frac{P}{k_BT}\simeq \frac{1}{V-Nv_0/2}$$ ... well ##(N-1)x \simeq Nx## if ##x<<Nx## right? Presumably N is a very big number?
[edit] DH has it formally :)
Thanks for your help! DH, I assume that approximation is only valid for small x correct? It seems as if N is very large, then the approximation wouldn't be a good one.
Hmmm... I didn't check it properly.
We seem to be saying different things after all - I am pointing out that for large ##N##, ##N - 1 \approx N##.
You can get some very hokey-looking approximations in physics.
Yes, N is large, which makes step 25 valid, where N-1 is simplified to N. The assumption that makes step 24 valid is that ##Nv_0 \ll V##. In other words, this assumption says the volume excluded by all of the gas molecules is much less than the total volume of the system.
