Klein Paradox: Momentum in the Classically Forbidden Region
4 replies · 3K views
flyusx
The Klein paradox is illustrated with particles traveling along the -axis incident on a potential step of strength where and . Determine the momentum in the classically forbidden region.
$$E^{2}=m^{2}c^{4}+p^{2}c^{2}$$ $$v_{g}=\frac{\partial E}{\partial p}$$
I'm currently reading over a little bit of relativistic quantum mechanics (with an emphasis on the need to transition to QFT) and have stumbled upon something I can't seem to figure out.
I was taught the Klein paradox as an example for why we need QFT. Pure relativistic quantum mechanics leads to (for instance) reflection coefficients exceeding unity and negative probability densities. My textbook follows very closely to the lecture notes published here (spinless case) and here (spin-1/2 case). They both come to the same conclusion.
My confusion amounts to the following. Consider the potential step $$V(x)=\begin{cases}V_{0}&z>0\\0&z\leq0\end{cases}$$ In the spinless (Klein–Gordon) case with ##E+mc^{2}>V_{0}##, we take momentum in the classically forbidden region to be $$-\sqrt{\frac{\left(E-V_{0}\right)^{2}}{c^{2}}-m^{2}c^{2}}$$ We specifically pick the momentum to be negative rather than positive. This is because the group velocity is $$\left(E-V_{0}\right)^{2}=p^{2}c^{2}+m^{2}c^{4}\to\frac{\partial E}{\partial p}=v_{g}=\frac{pc^{2}}{E-V_{0}}$$ Thus a negative momentum yields a positive group velocity and a rightwards-propagating wave. If we took a positive linear momentum instead, we would have a leftwards-propagating wave. Additionally, if we were considering an energy regime other than the Klein paradox, so ##E+mc^{2}>V_{0}##, a positive momentum would correspond to a positive group velocity.
The logic above makes sense to me. When I move on to the case for spin-1/2 particles, I see in the lecture notes and my textbook that the transmitted wave is given the positive momentum $$\sqrt{\frac{\left(V_{0}-E\right)^{2}}{c^{2}}-m^{2}c^{2}}$$ The subsequent calculations in both sources yield results consistent with the Klein paradox. For instance, the magnitude of the reflected probability current exceeds that of the incident probability current. However, nowhere did we enforce a positive group velocity. By picking the momentum in the classically forbidden region to be positive, doesn't this correspond to a negative group velocity and hence a leftwards-propagating wave? Why was the group velocity analysis method not used here?
Doing some further digging, I came across an article titled Motion of a wave packet in the Klein paradox by Nitta, Kudo, Minowa (Am J Phys, Vol 67, No 11, Nov 1999); I've linked a PDF here. On page 969, the authors present the possibility of taking the momentum in the classically forbidden region, what they call region II, to be negative instead of positive. They claim that doing so 'assumes that the negative-energy states in region II are empty', which is inconsistent with Dirac's hole model. Could this be the resolution to my confusion?
I have once learned that by incorporating the Quantum Field Theory perspective that "pair production is occurring from the Dirac sea filled with negative-energy states," this paradox of momentum and group velocity is completely resolved. Do you share the view ?
I have been working on this in the past few days but cannot seem to figure out how. I adopt the Dirac sea interpretation regardless because it seems to be the only bandage-fix for the Klein paradox in RQM available.
Is it simply because pair-production occurs, and the additional electrons travel backwards, therefore the group velocity is negative? I suppose this is consistent with the Klein–Gordon (spinless) case where the group velocity is positive because the transmitted bosons are interpreted to propagate rightwards. But then, the (spin-half) Klein Paradox needs its Dirac sea resolution to determine the proper momentum sign, which yields for the Klein paradox in the first place.
In the Klein paradox regime, the negative-energy solutions of the Dirac/Klein–Gordon equations should not be interpreted as particles in the usual single-particle quantum-mechanical sense. In quantum field theory, they are instead reinterpreted as positive-energy antiparticle states. I wish it might be of your help though I myself have not investigated your problem deeply.
Your equation
$$v_g=\frac{\partial E_\pm}{\partial p}=\frac{2pc^2}{E_\pm-V_0}$$
$$E_{\pm}=\pm\sqrt{p^2c^2+m^2c^4}+V_0$$
For positive energy branch there is no problem
For negative enerygy branch positron has positive energy ##-E_- >0##. velocity of positron is
$$v_g=\frac{\partial (-E_-)}{\partial p}=-\frac{2pc^2}{E_- - V_0}$$
So directions of p and v coincide by this intepretation. I hope I do not make mistakes here.
Loosely, in the relativistic theories the probability density ##~\psi^*\psi~## is replaced by the charge density operator ##~\psi^\dagger \psi~## (since probability can't be negative). In Klein-Paradox, the ingoing state is a single electron, so up to a possible sign its probability distribution is like the charge probability. The outgoing (scattered) state is a superposition of a single particle and state(s) with (at least) 3 particles: the "original electron", a positron (hole) and an additional electron (the one elevated from the "sea" to create the hole). In QFT it is called "pair production". If you send in a wave packet (representing the ingoing electron), the scattered "wavefunction" will contain 2 packets, representing the charge/current distribution contributions from all the states in the superposition (each containing 2n+1 particles, n=0,1,...). Remember: a positive current in one direction is like a negative one in the opposite direction. Since the outgoing state (above the 2m threshold) is not even an eigenstate of the number operator, an attempt to deduce the motions of the individual particles from the scattered wavepackets is bound to run into difficulties. The ##~T+R=1~## relation now implies conservation of total charge: it is equal to the charge of the ingoing electron.
