Approximation method for difference of two square roots
4 replies · 4K views · last reply
Mathematics news on Phys.org
Lets see - the equation would have been:
[tex] \frac{1}{c}\sqrt{<br /> H^2 + \frac{1}{4}\left ( <br /> \frac{D}{2}-v\Delta t<br /> \right )^2<br /> } - \frac{1}{c}\sqrt{<br /> H^2+\frac{D^2}{4}<br /> } \approx -\frac{1}{2}\frac{v \delta t}{c}\frac{D}{\sqrt{H^2 + \frac{D^2}{4}}}[/tex]
The text says this is "to first order in [itex]v\Delta t[/itex]" ... which means he took the Taylor Series to first order, putting [itex]x=v\Delta t[/itex] about [itex]x=0[/itex].
Taking the LHS for f(x), the 1st order Taylor approx is:
[tex]f(x) \approx f(0) + x{f^\prime}(0)[/tex]
He just rewrote the delta-tee to emphasize it's small size.
I havn't actually crunched the numbers but it looks about the right shape - the deriverative gets you the -1/2 and pulls the vδt outside the root - putting the root itself in the denominator.
Thanks, I appreciate.
I suspect that 1/4 in the first square root is not supposed to be there.
If you leave it off, then the zeroth order term vanishes at x=0 and
[tex]f^\prime (v\Delta t) = \frac{1}{c}\frac{1}{2}\left [ H^2 + \left ( \frac{D}{2} -v\Delta t \right )^2 \right ]^{-1/2} 2 \left ( \frac{D}{2} -v\Delta t \right ) (-1)[/tex]
(Leaving it messy to show the working.) So the first order term, [itex](v\delta t) f^\prime(0)[/itex], comes out as shown.
Otherwise you end up with:
[tex] f(v\delta t) \approx <br /> <br /> \frac{1}{c}\sqrt{H^2 + \frac{1}{4}\frac{D^2}{4}} -<br /> \frac{1}{c}\sqrt{H^2 + \frac{D^2}{4}} -<br /> <br /> \frac{1}{8}\frac{v\delta t}{c}\frac{D}{\sqrt{H^2 + \frac{1}{4}\frac{D^2}{4}}}<br /> [/tex]
I have not found any reason for the division by 4 in the equation for PDsat-B(B:2) since it should just be the distance from B to the satellite (in position 2) by Pythagoras.
Indeed, the 1/4 in the PDsat-b(B:2) term is a typo error.
Thanks again
