grassyourhorse
- 5
- 0
- TL;DR
- Reading papers on boltzmann brains seem to suggest our current models predict an infinite number of boltzmann brains that are produced by thermal fluctuations in a de sitter causal patch. While carroll has argued that such fluctuations dont occur, it seems that the majority still believe boltzmann brains are real due to reasons such as coherent histories or finite hilbert spaces
Dyson kleban susskind showed that if their idea of horizon complementarity is correct then boltzmann brains should vastly outnumber normal observers like us. However, there is some caveats, namely hilbert space needs to be finite dimensional. We currently assume that Hilbert space is infinite dimensional so our universe reaches a bunch davies vacuum. Sean carroll argues that in this state there can be no fluctuations since there are no measuring devices. However, cant it be argued that the environment system split is arbitrary so you could in principle see how decoherent branches with Boltzmann brains will appear even in a stationary state by choosing a basis. See seth lloyd paper (https://arxiv.org/pdf/1608.05672). Additionally, isnt it impossible to define a time invarient vacuum when you have massless fields such as gravity or an inflaton field so is the assumption that our universe approachs the bunch davies vacuum even legit? Lastly, does the horizon in bunch davies vacuum serve as an measuring device since it effectively cuts off causal connection to degrees of freedom that was once entangled?
