Are Mu and Lambda the Key to Solving this Line Intersection Problem?
  • Thread starter Thread starter lionely
    Lambda Parameters
12 replies · 3K views
lionely
the lines l2[/SUB and l3
are given by
l1 : r = 10i + j + 9k + μ(3i+j+4k)
l2: x= (y+9)/2= (z-13)/-3
l3 r= -3i-5j-4k + λ(4i+3j+k)
where mu and lambda are parameters.
d) Show that AC=BC
A(4,-1,1) this was given, I calculated and got B as (5,-1,-2) and C (1,-2,-3)
This I what I did so far
I found AC ( -3,-1,-4)
BC(-4,-1,-1)
I also found the mods of AC and BC to see if they were equal but, they're not.
are given by
where μ and λ are parameters.
d) Show that AC=BC
BC(-4,-1,-1)
It looks like you haven't given us the whole problem, although we can read between the lines to figure out most of what's missing:
Two of the lines intersect at point A, which is at (4,-1,1).
Two of the lines intersect at point B.
Two of the lines intersect at point C.​
Now,
Calculate vector AC and see if its magnitude matches the magnitude of either of the other two vectors.
Added in Edit:
B is at (5,1,-2) not (5,-1,-2)
it doesn't Magnitude of AC is root 26
while magnitude of B is root 30 and C is root 14.
sorry!
I found BC and the magnitude of it is root 26! Thank you for pointing out the mistake in the coordinates of B!
sorry!
Good deal !
Ummm there's is one more part to the question , It says write down the coordinates of the point D on AB such that CB is perpendicular to AB.
I'm not sure what to do... do I do something with the dot product?
Well, using the dot product will be a good way to check your answer, but think about the overall situation.
Triangle ABC has
length AC = length BC .​
Where should point D be on AB so that ... looks like a typo ?
write down the coordinates of the point D on AB such that CD is perpendicular to AB.
OK! That makes sense.
Now,
Triangle ABC has
Where should point D be on AB so that CD is perpendicular to AB.
In the middle of AB?
Yes. D is the midpoint of AB .
LOL so wait I can find find AD then just get D and that's it?
Yes. That's it.
You can check your result by seeing if the appropriate dot product is zero.
Thank you again for the help. Homework is now finished!
