Are (∨n∈ℕ)(n∈M→s(n)∈M) and (∨n∈M) s(n)∈M equivalent?
6 replies · 2K views
Danijel
So , what I was wondering about was a slight difference in notation, for which I am not certain if correct (mine, in particular.).
The induction axiom says: If M is a subset of ℕ, and if holds that:
a)1∈M
b)(∨n∈ℕ)(n∈M→s(n)∈M)
then M=ℕ.
Now my question is: why do we write (∨n∈ℕ)(n∈M→s(n)∈M), instead of (∨n∈M) s(n)∈M? Are these equivalent? Because, if we say n ∈ M, we consider that n∈ℕ and n∈M, since M⊆ℕ.
Thank you.
a)1∈M
then M=ℕ.
The first is rigorous, the second a bit sloppy. Induction means, we assume ##n \in \mathbb{N}## and ##n \in M## in order to conclude ##s(n)\in M##. To write for all ##n \in M## is shorter, but ##M \subseteq \mathbb{N}## is suppressed.
Are those equivalent?
I'd say yes. However, since we are in the field of logic here, I would prefer the former over the latter. The explicit deduction ## \rightarrow ## makes the induction principle more clear.
No, the two statements are not equivalent. For example, for each natural number n it is True that "If n < 0 then the successor of n is < 0". The Truth of that statement follows from the convention that an if-then statement is True whenever the if-clause is False. By contrast, the statement "For each natural number n, n < 0" is False.
This illustrates why step a)## 1 \in M## is a crucial part of proof by induction.
Note that ##M \subset N## does not rule out the possibility that ##M## is the empty set.
But if ##M## is the empty set, both statements are still true. (!?)
This may be a silly way to approach it, but I thought of this.
(∀n∈M) s(n)∈M is by definition equivalent to (∀n)(n∈M →s(n)∈M), which is obviously not equivalent to (∀n∈ℕ)(n∈M →s(n)∈M). Another way to think about it is that these can become equivalent if we consider a few things, which is not what we usually do.
These three sentences are in fact equivalent in this case, since it is assumed that M⊆ℕ.
But I agree with Fresh 42 that the form (∀n∈M) s(n)∈M is not good pedagogically, since it seems less clear with this form that inductionn means going from n to s(n).
I see your point. Yes both are true if the notation "##\forall n \in M"## is interpreted to mean "For each n, (if ##n \in M## then...)" With that interpretation, the two statements are equivalent by definition.
In the formal logic I have seen, the notation for quantifiers is in the form ##(\forall x) (...)## rather than having any operation immediately after the quantifier - so we would not write "##\forall x \in M##" for "##\forall x > 0##". However, people also use the notation for quantifiers informally, as if "##\forall##" can be used to abbreviate the English phrase "for each" in any English sentence where "for each" occurs.
