Calculating sample size?
  • Level: Undergrad
  • Thread starter Thread starter Andy Resnick
17 replies · 3K views · last reply
Education Advisor
Insights Author
There has to be a simple way to calculate this, I just don't have a clue how.
The setup:
I'm teaching cell culture methods to some students, and part of the process is checking for contamination- after making culture media, a small volume is put into the incubator overnight and checked for bacterial growth in the morning.
The question (using 'normal' units for things)
"When you made 100 milliliters of solution, there could also be a small number of bacteria present, perhaps as much as 0.1 nanomolar. How much volume do you need to sample in order to be at least 99% confident that you captured at least 1 bacterium?"
Thanks in advance....
It seems 1ml would work. I guess you could imagine from 0.1 nanomolar = numerically how many bacteria (6.9E12). Then assume they are evenly distributed.
Take your volume of 100ml and divide it into 100 1ml. So each 1ml would have 1/100th the number of bacteria (6.0E10).
I'd approach it by noting that if there were one bacterium in a volume ##V## (##V=100\mathrm{ml}## in your case) and I drew a volume ##v##, the probability of not getting the bacterium would be ##1-v/V##. The probability of not getting any of ##n## bacteria whose locations are independent random variables is therefore ##(1-v/V)^n##. Requiring this to be less than 1% gives us $$
\begin{eqnarray*}
0.01&>&(1-v/V)^n\\
0.01^{1/n}&>&1-v/V\\
v&>&V(1-0.01^{1/n})
\end{eqnarray*}$$For your case where the number of bacteria is ##n\approx 6×10^{12}##, ##v## is pretty much indistinguishable from zero. You would have to try really really hard not to get a bacterium unless they all clump in one corner or something.
Is that a valid assumption, though? @Andy Resnick -- what are the typical causes of contamination in this setup? Does it usually come from contaminated dishes (so likely evenly distributed), or contaminated dispensing gear (so likely the contamination will be washed out with the first solution dispensed), or something else?
Thanks to everyone for the replies, let me address them:
Apparently, I grossly overstated the (maximum) contamination level- obviously, as the number of contaminants decrease, I need to sample larger and larger volumes, but that would seem to quickly approach a limit when I need to sample the entire volume (or a substantial fraction of it. This is clearly not what is done in the biomedical or food industries:
"[xxx] brand, [YYY] cell culture liquid products are prepared by an aseptic process for which each step has been validated to ensure that all products meet the industry standard sterility assurance level of 10^-3; i.e. product that demonstrates a contamination level of no more than 1 of 1,000 units during the manufacturing process. The highest level of sterility assurance (equal to or greater than 10^-6) cannot be achieved without terminal sterilization which is harmful to the performance of cell culture products."
If I understand this correctly, the "industry standard sterility assurance level of 10^-3" means less than 0.01 bacteria/milliliter. If I make up a 1 liter batch, there can be up to 1 bacterium present. How much volume do I need to sample to meet the assurance level?
Other than grossly overestimating the contamination level, it a valid assumption. Ultimately, the typical causes of contamination are 'user error': touching any surface with a sterile pipette tip; improper sterilization of gloves or work area; rapid movement that brings outside air into the culture hood; stuff like that.
jedishrfu said:
Sometimes you need to put a stick in the ground and make a guess.
Which is what I have been doing all along :) So far it's worked out well (using the secret weapon of 'geometrical mean', I typically withdraw 2ml out of a 100 ml batch), I am/was hoping for some rational calculation to support my guess.
I think it depends a bit what that ##10^{-3}## means. You could argue that "of every 1,000 bottles we sell, 999 are sterile and the last one is actual swamp water" meets that standard, in which case you don't need to sample at all, you just throw away the bottle with the silt in it. Reading your quote of how the manufacturers describe it and your comments about typical contamination sources I think they do mean something of this sort, although not quite so exaggerated. So the question you are trying to answer seems to be "do I have the swamp water or not". Is that where the 0.1 nanomolar came from? You either have a sterile sample or a 0.1 nanomolar solution? If so, then 2ml is way more than enough.
I made up 0.1 nanomolar, the reality is that even a single bacterium (or mold spore, or yeast cell, or...) is too many. I should have phrased my original question like this:
"A volume of media may have a single bacterium present. How much of the volume do you need to sample to be 99% confident that no bacteria are present?"
A colleague mumbled something about Poisson distributions but then wandered off....
jedishrfu said:
Perhaps what you need is an EPA test protocol where you filter the 100ml through a couple of filters and culture the filters for aerobic, anaerobic and fungal contamination.
The sampling strategy to get to 99% means testing most of the water if not all of the water.
https://www.epa.gov/sites/default/files/2015-08/documents/method_1604_2002.pdf
I don't want to wander too far off topic here- I'll simply note that the protocol references "An appropriate volume of a [water] sample", and my question is specifically targeting the word "appropriate". How is that volume determined?
Was it simply a guess that has been converted into accepted practice? Is there any rational basis for determining what the appropriate sample volume is, given a total volume of material under test?
Maybe "A volume of media may have a single bacterium present. How much of the volume do you need to sample to be 99% confident that no bacteria are present?" is not a simple question to answer...
Yeah, sometimes a heuristic is used that's easy to remember, like the famously wrong one used during COVID to stand 6 feet apart, which was traced back to some journal papers in the 1950s and to the droplet model vs. aerosol transmission, where there is no set distance. Aerosols continue to follow air movement, whereas droplets fall based on their weight and size.
Personally, though, I feel the filtering and culturing approach gives much better safety than doing subset testing.
I think I'd try this Bayes fashion:$$p(B|A)=\frac{p(A|B)p(B)}{p(A)}$$In your case you are interested in ##B## being ##N##, the number of bacteria in the original volume, and ##A## being ##n##, the number of bacteria found in your sample, and the result will depend on the volume of sample drawn. You need to know three things - ##p(n)##, ##p(N)## and ##p(n|N)##
##p(n|N)## is easy - given that you draw a volume ##v## from a volume ##V## each bacterium has a ##v/V## chance of being in the volume you drew. So this is a binomial distribution:$$p(n|N)=C^N_n\left(\frac vV\right)^n\left(1-\frac vV\right)^{N-n}$$
##p(N)## is where the Poisson distribution comes in - ##p(N)=\lambda^Ne^{-\lambda}/N!##. The manufacturers say that a fraction ##c## of their bottles are fine (##c=999/1000## here) and there's at least one bacterium in the last one, so we want to pick ##\lambda## such that ##p(0)=c##. So ##\lambda=-\ln c##.
##p(n)## is easy to write down but messy to calculate. $$\begin{eqnarray*}
p(n)&=&\sum_{M=0}^{\infty}p(n|M)p(M)\\
&=&\sum_{M=0}^\infty\frac{M!}{(M-n)!n!}\left(\frac vV\right)^n\left(1-\frac vV\right)^{M-n}\frac{\lambda^Me^{-\lambda}}{M!}\\
&=&\sum_{M=0}^\infty\frac{\lambda^Me^{-\lambda}}{(M-n)!n!}\left(\frac vV\right)^n\left(1-\frac vV\right)^{M-n}
\end{eqnarray*}$$where I've used ##M## as a dummy variable in place of ##N## inside the sum.
So where does that leave you? Well, you don't have any bacteria left in the bottle if ##n=N## so, mathematically, if you draw a sample and find a bacterium you could accept the bottle anyway if you are reasonably confident there was only one. I suspect you wouldn't, though. So the question is "given that you drew a sample of volume ##v## and found ##n=0## bacteria, what's the probability that there are ##N=0## bacteria in the remainder?".
##p(n=0|N=0)=1## obviously (if there were no bacteria in the bottle then your sample will certainly be clean). ##p(N=0)=c## according to the manufacturer. And$$\begin{eqnarray*}
p(n)&=&\sum_{M=0}^\infty\frac{\lambda^Me^{-\lambda}}{(M-n)!n!}\left(\frac vV\right)^n\left(1-\frac vV\right)^{M-n}\\
p(n=0)&=&\sum_{M=0}^\infty c\frac{(-\ln c)^M}{M!}\left(1-\frac vV\right)^{M}
\end{eqnarray*}$$Note that the ##m##th term in the sum is ##-\ln c(1-v/V)/m## times the previous one. That's manifestly less than 1 (and positive, since ##\ln c## is negative), so the terms are monotonically decreasing.
Putting all that together and including ##c=0.999##:$$\begin{eqnarray*}
p(N=0|n=0)&=&\frac{p(n=0|N=0)p(N=0)}{p(n=0)}\\
&=&\frac 1{\sum_{M=0}^\infty \frac{(-\ln 0.999)^M}{M!}\left(1-\frac vV\right)^{M}}
\end{eqnarray*}$$
Noting that ##-\ln 0.999\approx 0.001## and computing the first three terms we get$$
p(N=0|n=0)\approx\frac 1{1+0.001(1-v/V)+\frac 12 0.001^2(1-v/V)^2}$$We can see it's ok to neglect the third term too. Doing so, and setting ##p(N=0|n=0)=0.99## as per your original specification, we find ##v/V\approx -9##.
What does a negative sample fraction tell you? It tells you that if you buy the manufacturer's 999/1000 claim, you are already 99.9% confident that the bottle you have is clean, so you don't need to do any sampling to get to 99% confident. Sampling any volume will increase your confidence above 99.9%, but probably not by much since you're already very confident.
What is your scenario, exactly? Are you training students to deal with a situation where you think the manufacturers are full of natural bovine-sourced fertiliser and actually you think ##c## is more like 0.9 than 0.999? Or are you training them to be QA on the production line and trying to confirm that their products meet their published ##c=0.999## standard? Or are you just checking that you didn't somehow get a batch of tap water this time? Or something else?
Ibix said:
I think I'd try this Bayes fashion:<snip>
OMG thank you! This is EXACTLY the kind of answer I was hoping for. I'm saving and printing it out for permanent reference.
The exact scenario is simply "training students to work in an aseptic environment". Most of the 'stock solutions' are commercially obtained and are contamination-free, but when students are learning how to work in the hood they (usually) have poor technique. The typical errors are either touching a sterile instrument (there is a proper way to unwrap an aspirating pipette!) or liquid splashing/aeration. So, 'best practice' is that once they make up a solution, which can have up to a dozen components, before using it on defenseless cells they first test the media for contamination by incubating a test volume overnight. We can't just sterile-filter the media for a couple of reasons: 1) some proteins stick to the filter, removing them from solution; and 2) poor technique when sterile filtering doesn't help.
Just as an aside: "why don't you just add antibiotics to the media?". We do have a range of antibiotics to combat bacteria/mold/yeast/mycoplasma, but we do not routinely add these because 1) chronic antibiotic use promotes antibiotic-resistant strains and 2) for some reason, when cells are frozen for later use, the presence of antibiotics interferes with the freezing process and cells don't survive as well.
Your answer is fantastic b/c This gives students a clear application of using statistical methods. Whether or not they go on for QC/QA jobs is up to them :)
Seriously- thanks!!!!
You're welcome.
Ok. In that case, you probably want to set ##c## to something much lower than 0.999 - you want to use your own ballpark estimate of the rate at which the students manage to make sterile solutions. The rest of the maths should proceed the same, except if ##c## is really low then you shouldn't neglect the second (third, fourth...) terms in the series. That potentially means you could have a polynomial in ##v/V## to solve instead of the linear equation I got (because the next term was around 0.001 times the size with ##c=0.999##). If you don't fancy solving polynomials then you might estimate a solution using the linear approach and then see how big the next couple of terms are using that ##v/V## and up it that much (i.e., if the ##M=2## term is 0.1 times the ##M=1## term, and the ##M=3## term is 0.03 times the ##M=1## term you could bump up your ##v/V## by a factor of 1+0.1+0.03). This approach probably isn't right, but it should put you in the ballpark (if you don't want to consider asking Wolfram Alpha to solve the polynomial for you).
jedishrfu said:
Perhaps your students could try the filtering too and compare their calculations with a physical experiment.
Well.... I'm definitely not going to intentionally contaminate a solution (positive control).
One idea is to have the students do it anyway to learn the procedure and to see which student contaminated their sample.
Veritaseum did a video a few years back where he put uv powder on a teachers hand and asked her to greet their class shaking the hands of the first three students.
At the end of the day, UV light revealed little handprints everywhere that moved from teacher to three students to all 15 first graders and the whole classroom was now contaminated.
Now imagine what COVID-19 could do.
