Are There Part-Time Opportunities in Mechanical Engineering and Research?
  • Thread starter Thread starter ArcherVillage
    Jobs
Part-time opportunities in mechanical engineering and research are limited, particularly in research roles, which often require full-time commitment due to the nature of the work. Mechanical engineering involves complex subjects like structures and thermal dynamics, making it challenging to find part-time positions. The discussion highlights the importance of passion in research, as working on topics of interest can significantly enhance job satisfaction. The mention of specific research areas, such as the effects of temperature on living tissue, underscores the diverse applications of mechanical engineering. Overall, individuals should carefully consider their interests and the demands of the field when exploring part-time options.
ArcherVillage
Hi again (this is my second post in a very short period),
I don't quite know if I like working full-time as an engineer/researcher, and was curious about what my options are for part-time work as a researcher/mechanical engineer. I'm guessing that, for research, there probably isn't anything, but hope springs eternal.
Thank you for your time and thought.
Mechanical engineering deals a lot with structures and/or heat-related things. It's not simply something you can pick up easily...
With regards to reserach, there are always new breakthroughs with regards to stresses/strains of materials---one of my professors in college studied how rabbit livers would change while undergoing vast temperature changes---this was to study the effects of freezing on living tissue. Freezing is also a method of destroying cancerous tumors & so forth.
You must research what you love, or love what you research... If not, you'll be bored. Period.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
