Are Units for Phase Calculations in Wave Problems Accurately Applied?
MathewsMD
I have a few waves questions I would really like to have addressed. I'll post my logic/solution for each question and any feedback is welcome.
Q. 10: This one seems pretty straight forward but shouldn't the units be 3.0 rad/m? Since x is in meters and we're not changing the order of magnitude for any other variables, I don't quite see how the units cancel out properly...I'd just like to confirm this.
Q. 20 and 21: This seems also pretty simply but I may be missing something here. To find instantaneous velocity is to take the derivative (find slope of tangent) at a point. Looking at the question like this, my answer for 20 would be E and 21 would be D. Am I missing something fundamental here?
Q. 31: This question also didn't make complete sense to me. Looking at 3, the tension appears to be the greatest since there's one string and 2 masses for which it must be keep up. 2 looks like the lowest and 1 is intermediate, since FT ~ v2. Once again, am I missing something big here?
Any help with these questions would be great! Thanks!
  • Multiple-choice physics question 10: wave y(x,t) = 0.1 sin(3x + 10t), with x in meters, y in centimeters, t in seconds; options A 0.10 rad/m, B 3π rad/m, C 10 rad/m, D 10π rad/m, E 3.0 rad/cm; answer E.
  • Transverse sine wave with point P on the axis, a dashed horizontal line, and an arrow labeled v to the right showing wave travel; answer choices A to E give up, down, right, diagonal, and no direction.
  • Sinusoidal transverse wave on a string with point P marked on the rising part of the curve, a dashed horizontal line through the middle, and a rightward arrow labeled v. Answer choices A to E listed at left.
For Q10, you're right, the units should be rad/m.
For Q20 and Q21, try to imagine what happens to point P as the wave moves to the right. The waves are traverse in both cases, so a point "on" the wave cannot by definition have a longitudinal velocity component, just a traverse component, hence it can only go up or down.
As for Q31, I don't see any sort of picture so I can't really help out much.
kontejnjer said:
for q10, you're right, the units should be rad/m.
For q20 and q21, try to imagine what happens to point p as the wave moves to the right. The waves are traverse in both cases, so a point "on" the wave cannot by definition have a longitudinal velocity component, just a traverse component, hence it can only go up or down.
As for q31, i don't see any sort of picture so i can't really help out much.
q. 31
  • Multiple-choice physics question 31 with three diagrams of identical strings under tension from hanging 5 kg blocks; answer options A through E listed, marked ans: D.
If you haven't done so already, draw free body diagrams for all the cases depicted. You can then figure out the tensions in all of them. Notice that case 1 and 3 are equivalent because the forces on both ends of the rope are the same (in the first case, the wall must exert a force equal in magnitude to that of the weight of the block, otherwise it wouldn't be in equilibrium anymore).
