Area enclosed by a function involving 2 power towers
  • Level: Undergrad
  • Thread starter Thread starter Saracen Rue
    Area Function Power
Saracen Rue
TL;DR
Evaluate the following integral ##\int_0^1 ((−ln(x↑↑(2k)))↑↑(2k+1))dx## as ##k \to \infty##
I've been playing around with Up-Arrow notation quite a lot lately and have come up with the following "thought experiment" so to speak. Consider the following function: $$f(x)=(−ln(x↑↑(2k)))↑↑(2k+1)$$ $$\text{Where }k∈\mathbb{Z} ^+$$
In the image below we can see some examples of what this function looks like for the first ##5## values of ##k##:
Plot of five curves f_k(x) on x from 0 to 1, each rising from 0 at x=0, peaking, then falling back to 0 at x=1, with heights rising slightly as k increases. Legend lists f_{k=1}(x) = (-ln(x↑↑2))↑↑3 through f_{k=5}(x) = (-ln(x↑↑10))↑↑11.
It can be visually seen from the graphs that while the area under each graph does become larger for increasing values of ##k##, the rate at which the area is increases decrease. However, I went ahead and took the liberty of doing the calculations anyway. I found the difference in area between ## f_{k=2}(x)## and ## f_{k=1}(x)##, and then between ## f_{k=3}(x)## and ## f_{k=2}(x)##, and so on. I then took these values and plotted them as such:
GeoGebra plot of a decreasing curve approaching zero with points at x = 1 to 4 and 10, next to a regression formula with R squared = 1, and five definite integrals from 0 to 1 of successive differences f_k.
(Note: The graphs of ##f_{k=10}(x)##and ##f_{k=11}(x)## weren't included previously, they are only being used here now to help with the accuracy of the curve fitting)
Each point was plotted in the following manor: ##(1, \int_0^1(f_{k=2}(x)-f_{k=1}(x))dx), (2, \int_0^1(f_{k=3}(x)-f_{k=2}(x))dx), \text{etc}.##
The points were found to fit the general relationship of ##y_A \approx m_1 x_A^{a_1x_A+b_1}+c_1## extremely well, have an ##R^2## value very close to ##1##. This leads me to believe that this relationship appropriately represents the difference in area between different values of ##k## in ##f(x)##. Therefore, because this regression curve approaches ##0## as ##x## approaches ##\infty##, the area enclosed by the graph of ##f(x)=(−ln⁡(x↑↑(2k)))↑↑(2k+1)## must approach a constant value as ##k \to \infty##.
So, we know it does approach a constant value, we just need to find out what said value is. In other words, we need to evaluate $$\int_0^1 ((−ln(x↑↑(2k)))↑↑(2k+1))dx \text{ as } k \to \infty$$
The differences going to zero is not sufficient. ##\displaystyle \sum \frac 1 n## has the differences between partial sums going to zero, too, but clearly the sum diverges.
I think you can prove that 1 > fk > fk-1 for all x between 0 and 1, that is sufficient for convergence.
Thank you for letting me know. I was never taught about convergent/divergent series in school, so I'm still not very confident with this area of maths. I would very much appreciate if you could help with how to go about proving ##1## ##>## ##f_k## ##>## ##f_{k-1}## for all ##x## between ##0## and ##1##.
This should work (details to be worked out):
  • Show that ##1/e \leq x↑↑(2k) \leq 1##. It follows that ##0 \leq -\ln( x↑↑(2k)) \leq 1##, which means your integrand is between 0 and 1. That gives the upper bound on the integral.
  • Show that ##x↑↑(2k) \leq x↑↑(2k-2)##. It follows that ##-\ln( x↑↑(2k)) \geq -\ln( x↑↑(2k))##.
  • Show that ##x ↑↑ (2k+1) > x ↑↑ (2k-1)## and that ##x ↑↑ (2k+1) > y ↑↑ (2k+1)## for x>y.
  • Combine step 2 and 3 to show that ##f_k > f_{k-1}##.
