Arithmetic and our place value system
The discussion centers around the concept of the place value system in arithmetic, particularly how numbers can be represented in different bases. Participants explore the implications of base and exponent in various numeral systems, including base-10, base-7, and base-60, and consider the historical context and applications of these systems.
  • Some participants propose that the essence of the place value system is captured by expressing numbers in terms of powers of their respective bases.
  • One participant notes that while the term "power" is often used synonymously with "exponent," it is important to clarify that expressions like ##3^4## are not powers in the context of place value.
  • Another participant discusses the historical significance of base-60, linking it to timekeeping and angle measures, and mentions the Babylonians as early users of this system.
  • There is mention of binary (base-2) and hexadecimal (base-16) as commonly used bases in computer science, alongside less common bases like octal (base-8) and base-64.
  • One participant introduces the term "b-adic notation" and discusses its implications for numerical analysis and number theory, emphasizing the complexity of defining numbers without a deliberate choice of base.
  • Several participants seek additional resources and references on b-adic notation and related historical contexts, indicating a desire for further exploration of the topic.
Participants generally agree on the basic principles of the place value system and its representation across different bases, but there are nuances in terminology and implications that remain contested. The discussion does not reach a consensus on the definitions and applications of certain terms, such as "b-adic notation."
Some limitations include the potential ambiguity in the term "power" as it relates to exponents, and the varying historical contexts of numeral systems that may not be fully explored. The discussion also touches on the complexity of defining arithmetic foundations without reference to specific bases.
This discussion may be of interest to those studying mathematics, computer science, or history of mathematics, particularly in relation to numeral systems and their applications.
mark2142
TL;DR
Does arithmetic in certain base of powers lead to number system in different bases ?
A power has two parts. Base and Exponent.
A number 423 in base 10 can be written in other bases as well:
1. 4* 10^2 + 2*10^1 + 3*10^0 = 423
2. 1*7^3 + 1*7^2 + 4*7^1 + 3*7^0 = 1143
3. 7*60^1 + 3*60^0 = 73
All three expressions are equal in quantity. But I have written the multiplier of powers to form numbers in different bases. Is this what place value system is in essence ?
Mathematics news on Phys.org
mark2142 said:
TL;DR Summary: Does arithmetic in certain base of powers lead to number system in different bases ?
I would call them equal in value.
For the most part, yes. However, the term "power" is synonymous with exponent, so for example, ##3^4## isn't a "power" -- it's an expression where 3 is raised to the fourth power; i.e. with an exponent of 4.
Your examples show that ##423_{10} = 1143_{7} = 73_{60}##, with subscripts shown to indicate the various bases.
Speaking of number-system bases, 7 is not commonly used, but there is some history with base-60, as it is the base of our system of time (60 minutes in an hour and 60 seconds in a minute) as well as in angle measures, with the same subdivisions of a degree as of an hour. My understanding is that the Babylonians were the first to work in base-60.
In computer science two of the most commonly used number bases are binary (base-2) and hexadecimal (base-16). Some lesser-used number systems are octal (base-8), which was used in early computers, and base-64, which is used in some internet protocols to transmit data in a compact form.
Yes. It is called ##b##-adic notation (not to be confused with ##p##-adic numbers). The ##b## is the basis, in your examples ##b=10, 7, 60.## It's likely our ten fingers that led to the success of decimal (##10##) numbers.
It is a choice. The numbers are the same, only the notation differs. Computers work with powers of two as bases. It has an interesting consequence: You can do numerical analysis based on a deliberately chosen basis, which is all about computational algorithms, but you cannot do number theory based on a deliberately chosen basis. That's why number theory is mainly about divisibility as its central point of interest.
The logical foundation of arithmetic isn't so simple as it may look at first glance. How do we define our numbers without referring to a deliberate choice? It leads you directly into set theory.
fresh_42 said:
It is called b-adic notation
Can you give me a link where I can read about it? I cannot find on google.
The best I could find is probably:
https://www.gutenberg.org/files/17920/17920-pdf.pdf
I like that it includes historical considerations: the entire second part.
Here is a book:
https://www.amazon.com/Numbers-Grad...er-Ebbinghaus/dp/0387974970?tag=pfamazon01-20
I have found it online, but I assume it is copyright-protected, so I won't link it here even though it was on a British website.
The subject itself is so basic that it is hard to find, as it is more of a sidenote in regular calculus books rather than an isolated topic. Searching for it brought me to pages on which their digitalization is discussed, or other specific properties.
Here is "An Historical Survey of Number Systems":
https://www.math.chalmers.se/Math/Grundutb/GU/MAN250/S04/Number_Systems.pdf
I also found things like
https://www.sathyabama.ac.in/sites/default/files/course-material/2020-10/unit1_7.pdf
but I'm not so sure what it is,
or a fancy slideshow
https://www.cs.princeton.edu/courses/archive/spr15/cos217/lectures/03_NumberSystems.pdf
My book called it so: b-adic quotients ##\displaystyle{\pm \sum_{n=-k}^\infty a_nb^{-n}}.## I'm not quite sure whether this is a general term for it, which I thought it was, since I learned it from that book, or just a personal notation by that particular author.
  • · Replies 24 ·
  • · Replies 48 ·
