Create an Installment Plan for Mr. Budi's Annuity
  • Context: MHB
  • Thread starter Thread starter Monoxdifly
    Annuity
The discussion centers on creating an installment plan for Mr. Budi's loan of 2,000,000 IDR, which will be amortized over 10 years at an interest rate of 10% per annum. The calculated annuity payment is 1,228,913.42 IDR, leading to varying installment amounts due to interest calculations. The confusion arises from the use of the formula for annuities, particularly in the interpretation of the geometric series involved. The standard formula for calculating the present value of an annuity is also discussed, emphasizing clarity in mathematical expressions.
  • Understanding of annuity calculations and amortization
  • Familiarity with geometric series and their summation
  • Proficiency in using financial calculators or spreadsheet software
  • Knowledge of basic interest rate concepts and formulas
  • Research the standard formula for calculating present value of annuities: P = Ai / (1-v)
  • Learn about geometric series and their applications in finance
  • Explore financial calculator functionalities for accurate amortization calculations
  • Study common pitfalls in financial calculations to avoid confusion
Finance students, loan officers, and anyone involved in loan amortization or financial planning will benefit from this discussion.
Monoxdifly
MHB
Mr. Budi borrows 2,000,000IDR which will be amortized with 10 annuities. The first annuity will be paid in 1 year with 10% per year interest. Make the installment plan!
For the annuity I got A = [math]M\times\frac1{\sum_{n=1}^p(1+i)^{-n}}[/math] = [math]2,000,000\times\frac1{\sum_{n=1}^{10}(1+0,1)^{-n}}[/math] = [math]2,000,000\times\frac1{\sum_{n=1}^{10}(1,1)^{-n}}[/math] = [math]2,000,000\times\frac1{\sum_{n=1}^{10}(1,1)^{-n}}[/math] = [math]2,000,000\times\frac1{(1,1)^{-1}+(1,1)^{-2}+(1,1)^{-3}+(1,1)^{-4}+(1,1)^{-5}+(1,1)^{-6}+(1,1)^{-7}+(1,1)^{-8}+(1,1)^{-9}+(1,1)^{-10}}[/math]
([math](1,1)^{-1} + (1,1)^{-2} + … + (1,1)^{-10}[/math] is a geometric sequence with the first term [math]a = (1,1)^{-1}[/math] and ratio [math]r = (1,1)^{-1}[/math])
= [math]2,000,000\times\frac1{\frac{1-1.1^{-10}}{0.1}}[/math] = [math]2,000,000\times\frac{0.1}{1-1.1^{-10}}[/math] = 2,000,000 × 0.61445671 = 1,228,913.42
Thus, the annuity is 1,228,913.42.
On the end of first year:
Annuity = 1,228,913.42IDR
Interest : 10% × 2,000,000IDR = 200,000IDR
Installment : 1,228,913.42IDR – 200.000IDR = 1,028,913.42IDR
Remaining loan : 2,000,000IDR – 1,028,913.42IDR = 971,086.58IDR
On the end of second year:
Interest : 10% × 971,086.58IDR = 97,108.66IDR
Installment : 1,228,913.42IDR – 97,108.66IDR = 1,131,804.76IDR
Remaining loan : 971,086.58IDR – 1,131,804.76IDR = -159.718,58IDR
Why am I seeing negatives already?
I’m no expert on these things but this figure looks way too high to me. It means that at the end of the first of ten years you would have to pay back more than half the amount of your loan already.
Try that again...
$2,000,000\times\frac{0.1}{1-1.1^{-10}} = 2,000,000 \times \dfrac{0.1}{0.61445671}$
It's weird. My calculator app gives the same result for both $$1-1.1^{-10}$$ and $$\frac{0.1}{1-1.1^{-10}}$$.
1) Delete that app, or
2) Add parentheses.
tkhunny said:
2) Add parentheses.
Both 1-1.1^(-10) and 0.1/(1-1.1^(-10)) yield the same results on the calculator. And it seems like it's Windows calculator.
$$1-1.1^{-10}\ =\ 0.61445671057046825263559635552114$$
$$\frac{0.1}{1-1.1^{-10}}\ =\ 0.1627453948825116076230715715748$$
on my Windows calculator.
Okay, that leaves the other option.
This is why I do not recommend carrying such expressions as $1.1^{-10}$. Too much confusion.
I MUCH prefer this version:
$v = \dfrac{1}{1.1}$
$v^{10}$
So much cleaner.
Your ten payments are $v + v^{2} + ... + v^{10}$
Your sum is $\dfrac{v-v^{11}}{1-v}$, which is just as easily converted to $\dfrac{v\cdot\left(1-v^{10}\right)}{v\cdot i} = \dfrac{1-v^{10}}{i}$ if you like.
So much less to go wrong.
STANDARD formula (google would have given it to you Mr.Fly!):
P = Ai / (1-v) where v = 1 / (1+i)^n (same as TK's)
P = ?
A = 2,000,000
i = .10
n = 10
  • · Replies 16 ·
