MHB What Is the Distance Between Lines HO and PB in a Cuboid?
  • Thread starter Thread starter Monoxdifly
    Parallelogram
The discussion centers on calculating the distance between the lines HO and PB in a cuboid ABCD.EFGH, where AB = 4 cm, BC = 3 cm, and CG = 5 cm. The initial calculation using the parallelogram formula yielded $$\frac{1}{5}\sqrt5$$ cm, which was later confirmed to be correct after clarifying that OBPH is the correct parallelogram. The potential answers provided were $$5\sqrt3$$ cm, $$5\sqrt2$$ cm, $$\sqrt5$$ cm, $$\frac{5}{2}\sqrt2$$ cm, and $$\frac{5}{3}\sqrt3$$ cm.
  • Understanding of cuboid geometry and properties
  • Familiarity with the parallelogram formula
  • Basic knowledge of vector mathematics
  • Ability to perform calculations involving square roots
  • Study the properties of cuboids and their diagonals
  • Learn how to apply the parallelogram formula in three-dimensional geometry
  • Explore vector calculations in geometric contexts
  • Investigate distance formulas between skew lines in 3D space
Mathematicians, geometry students, and educators looking to deepen their understanding of three-dimensional shapes and distance calculations in geometry.
Monoxdifly
MHB
In an ABCD.EFGH cuboid with AB = 4 cm, BC = 3 cm, and CG = 5 cm there is a parallelogram OBFPH with O is located at the center of ABCD and P is located at the center of EFGH. The distance between the lines HO and PB is ...
A. $$5\sqrt3$$ cm
B. $$5\sqrt2$$ cm
C. $$\sqrt5$$ cm
D. $$\frac{5}{2}\sqrt2$$ cm
E. $$\frac{5}{3}\sqrt3$$ cm
By making use of the parallelogram formula, I got $$\frac{1}{5}\sqrt5$$. Do you guys get the same answer as me or any of the options?
Mathematics news on Phys.org
A. $$5\sqrt3$$ cm
B. $$5\sqrt2$$ cm
C. $$\sqrt5$$ cm
OBFPH is not a parallelogram. Did you mean OBPH? If so, then I agree with your answer $\frac15\sqrt5$. But maybe you misread the question?
Sorry, I meant OBPH.
15K
