Assigning numOnes with Modulo Operator
  • Context: C/C++
  • Thread starter Thread starter ineedhelpnow
    Operator
The discussion revolves around a programming problem involving the use of the modulo operator to calculate the number of one dollar bills a cashier distributes as change, given a specific amount. The context is primarily focused on coding and problem-solving within a programming assignment.
  • Homework-related
  • One participant initially suggests using "numOnes = 19 % 5" to calculate the number of one dollar bills, which is identified as incorrect.
  • Another participant points out that the correct expression should be "amountToChange % 5" instead of "19 % 5," emphasizing the need for a variable that can change rather than a fixed value.
  • A later reply confirms the suspicion that the modulus operator was applied to the wrong value, reinforcing the correction made by the second participant.
Participants generally agree on the correct application of the modulus operator, with a clear consensus on using "amountToChange" instead of a fixed number.
The discussion does not address potential edge cases or limitations in the problem, such as what happens with negative amounts or non-integer values.
ineedhelpnow
A cashier distributes change using the maximum number of five dollar bills, followed by one dollar bills. For example, 19 yields 3 fives and 4 ones. Write a single statement that assigns the number of distributed 1 dollar bills to variable numOnes, given amountToChange. Hint: Use %.
Sample program:
#include <iostream>
using namespace std;
int main() {
int amountToChange = 0;
int numFives = 0;
int numOnes = 0;
amountToChange = 19;
numFives = amountToChange / 5;
<STUDENT CODE>
return 0;
i only have to write code for the part that says <student code>. i tried numOnes = 19 % 5;
its wrong though. it passed two tests but failed one.
Technology news on Phys.org
oh i got it. it was supposed to be amountToChange % 5 not 19 % 5 because then it only works for one value
To which variable are you applying the modulus operator?
Good! (Yes)
That was my suspicion, that you were applying "% 5" to the wrong value. :D
  • · Replies 22 ·
  • · Replies 25 ·
