Astronomy Q&A game
  • Thread starter Thread starter Nicool002
    Astronomy Game
506 replies · 61K views
Originally posted by schwarzchildradius
OK, how do you measure the distance to the moon using lunar eclipse? What other observation of the moon must be made to find the distance to the sun?
Hipparchus measure the distance to the moon using eclipse data and got the result that the moon is 30 Earth diameters away which is quite close to the right answer.
However Hipparchus method is more complicated than I want to try to explain.
Earlier, Aristarchus (around 250 BC?) estimated the size of the moon compared with the Earth by observing an eclipse of the moon.
He judged that the Earth's shadow (roughly comparable in size to earth) was twice as big as the moon just by looking at the curve the shadow's edge made on the moon-----actually he should have guessed THREE times but he guessed twice the size.
Aristarchus was very back-of-envelope.
Knowing (in a rough sense) the size of the moon and the angle it made in the sky, Aristarchus could estimate the distance to the moon in Earth diameters.
He then observed the lunar dichotomy, which gave him at least a rough lower bound on the distance to the sun as a multiple of the distance to the moon.
Noting that the sun was an order of magnitude farther than the moon and therefore huge compared with the earth, he surmised a heliocentric model.
This guy was from Samos, same birthplace as Pythagoras.
Well Schwarzschild there is at least part of an answer
god save all Samians and the empire of the mind
Astronomy news on Phys.org
There you have it folks, righty-o.
The other observation was of the half moon - the moon is at 90 deg. from the sun when it is half full. You can use geometry to then (since you know the length of one side) find the distance and size of the sun. Your go.
Schwarzschildradius is a man of cultivation and discernment and has explained to us the method of lunar dichotomy.
In fact the sun is roughly 400 times the distance to the moon and therefore the angle (at halfmoon) is not 90 degrees but
90 degrees MINUS 1/400 RADIANS. Something like 89.8 or 89.9 degrees.
Aristarchus around 250BC measured it and got IIRC something like 89.5 degrees (he was clumsy at measuring angles, this Greek)
and so he judged that the sun was quite far away perhaps IIRC ten times as far as the moon! All the other greeks were quite astonished by this and could scarcely believe it. He should be awarded the Nobel prize postumously. Lunar dichotomy is a great phrase.
I like responding to questions a great deal better than I like asking them. Am tempted to appoint Schwarzschild my proxy and in invite him to pose a question for me. But perhaps it is better to keep it simple and stick by the rules.
QUESTION:
Describe "co-moving distance"
This is the astronomer's def of distance which works in the Hubble law v=H0 D
So if you ever use that law you need to understand what the comoving distance to an object is.
What is the comoving distance to an object (at this moment in time) which is currently receding from us at 30 thousand kilometers a second?
The answer to your particular question, is r=c/H, or something like 2e26 meters away. The answer to your general question, is that its the ratio of dx/dt (transverse velocity) to dθ/dt (proper motion), in other words, the distance measured by a "ruler" at specific time t.
Hello, your answer 2E26 meters is off by more than a factor of two so I'm afraid it will not do. But if you recalculate you will almost certainly get it.
Suggest using Hubble parameter of 71 km/s per Megaparsec
since that figure is not considered fairly reliable---the uncertainty has narrowed substantially about H0.
I should have been more explicit about the Hubble Law distance.
There is a particular definition of distance that works in the law
and other types of distance (angular size distance, luminosity distance, light traveltime distance) do not work.
In his javascript distance calculator
http://www.astro.ucla.edu/~wright/CosmoCalc.html
Wright refers to this definition of distance as the
"comoving radial distance, which goes into Hubble's law".
That expression contains a link to where the distance is
defined and described, using diagrams and some detailed
explanation. That "comoving distance which goes into Hubble's law" is what I am looking for.
But I won't insist on the general question---just get the
specific one right and you win the prize.
Fine
71 km/s/Mpc = 2.3e-18 s-1
R = 1.3e26 m
off by 21/2, much less than the uncertainty in H
or if you like,
3R = 3.9e26 m
Do you (or anyone) know the metric for Homogeneous Isotropic Cosmological Models?
Originally posted by schwarzschildradius
Fine
R = 1.3e26 m...
Still not right. You have to solve the equation v = HD
for D, where H is exactly what you say it is and
v = 30,000 km per second.
You do realize, do you not, that I said 30 thousand km per second----a speed which is not equal to the speed of light?
When I said your answer is off by more than a factor of 2, I meant *more* than a factor of two, also more than a factor of 3.
Your answer is off by more than a factor of 4, hint hint.
Your answer, namely 1.3E26 meters. Is 13.7 billion light years!
Way too big!
an algebra problem
Schwarzschildradius gives up.
Perhaps the problem is too simple for him.
The problem is, solve v = H0 D, for D
where v is 30 thousand km/sec, i.e. one tenth the speed of light,
and H0, the Hubble parameter, is (1/13.8 billion years).
Whatever. Its against the rules for me to keep guessing, and the value is in fact irrelevant because of uncertainty in H.
Both of us are nice people and we just experienced a power-of-ten problem. That's all and it happens quite regularly.
You kept saying 13.7 billion light years when you should have
been saying 1.37 billion light years. And you were off because
you thought that when I said "30 thousand km/sec" I was saying the speed of light.
When actually I was saying c/10.
I blame this on the metric system. If I had simply said "c/10"
then you would have gotten the right result immediately.
c is the natural unit to use in astronomy.
Let's have it be your turn, since you got the right answer except for the dratted order magnitude
General Comment:
Isn't this thread meant to be a "general" astronomy Q&A session instead of math excercises based on someone's assumptions (criteria) regarding some specific set of circumstances, sometimes theoretical and beyond "generally accepted"??
I don't mind the "Here is my theory" stuff, but there is another PF forum named "Theoretical Physics" where that is discussed with attempts to prove / disprove.
Carry on.
Originally posted by Labguy
General Comment:
Carry on.
Mentor hat on...
Overall, this forum is intended for "generally accepted" (dare I say, "mainstream") astronomy. "Here's my theory" goes into the Theory Development forum. Just keep that in mind...no major problems here so far.
As far as the general Q&A vs. math-heavy Q&A. I suppose it's either (1) up to Nicool002 (who started this thread) or (2) free market...if y'all want math, then knock yourselves out...if not, then this topic will evolve or die accordingly. Whatever. As long as it's good clean astronomy, then I'm happy. Certainly, many PF members have mastered general astronomy Q&A and are ready for more. But many PF members are new to astronomy.
Might I recommend 2 topics...one for beginners and one for advanced folks?
Originally posted by Phobos
Mentor hat on...
Hello Phobos, why don't you ask a question at kick off another round?
The last question was about the v=H0 D (Hubble law).
I asked, if v is a tenth of the speed of light (v = 30 thousand km/s)
then solve for D, the distance.
It did not get answered so maybe I can just invite someone to pose a question.
My thought is that the last question was about as basic, mainstream, and beginner-level as you can get in cosmology.
The Hubble parameter has been the main thing to measure and to use in estimating distance for several generations, the law
is fundamental to the field. So I wonder how the issue of "mainstream" arose. Is it too much math to involve a basic
equation like v=H0 D?
Afterthought. I guess the other most basic thing
in cosmology is the density of the universe (rho)
as it compares to the critical density (rhocrit) required for flatness.
For some decades cosmologists have been
talking about how "the fate of the universe" depends
on the ratio
rho/rhocrit-------whether it is less than one
or equal to one (flatness) or greater than one.
Would it by any chance be considered not mainstream to
ask a question about the critical density on this thread?
I don't recall that I have, as yet, but was just now wondering,
since it seems so central to the field that I can't really
picture what conventional cosmology would be like without it.
Just let's get this thing moving please ;)
OK, since no one else volunteers a question, I will ask:
What famous astronomer's mother was almost burnt as a witch?
(it didnt actually come to lighting the fire but she was tried
and came close to being burned)
god save the Hapsburgs and the holy roman empire!
marcus asked:
Johannes Kepler
Originally posted by J-Man
Johannes Kepler
Attaboy! Your question
What is a "reflection nebula"?
-Give a definition.
-Give an example.
-Extra points for brown-nosing.
-Give a definition.
-Give an example.
A reflection nebula is an accumulation of dust and gas where the light, usually blue in color, is reflected off the dust and gas from one or more embedded stars. M20, the Trifid Nebula, is an example where it is seen as blue. It also happens to be an emmission nebula as well, with light being emmitted from ionized Hydrogen, usually seen as red.
I don't know any brown-nose points.
Labguy answered:
Very good.
That's okay, it's still your turn.
Very good.
Ok, here is an EASY one. Two-parter.
(1) What event, important to observational astronomy, will happen on August 27, 2003? (**Later edit**: If we need very specific, you can use universal time OR EDT, since we are not always on the same day worldwide)
(2) When was this event last seen, to the same or greater degree, by any astronomer using any telescope or optical device to enhance the unaided eye??
Note: I expect this one to be answered instantly by the first PF member to read it...(?)
The closest approach of Mars in 73,000 years.
Never.
Never.
CORRECT.
Your question.
CORRECT.
Your question.
You tricky devil you.
Ok. Now if you read my other posts don't worry. I'm not going pseudo or philosophical on you.
What are the hypothetical circumstances, if we can show [mathematically] that one can control his position in time but not in space?
Edit:The language used may be a little optimistic:
What are the hypothetical circumstances, if we can show [mathematically] that one can affect his position in time but not in space?
I quoted since I wasn't sure if edits alert readers of a change.
So, are you asking the circumstances under which a particle can move in space but not in time? If v=c, this is the case I think. (T=infinity)
But that would violate Relativity. [?]
I don't think that qualifies unless you mean some really abstract circumstance that "actually" occurs, or could occur. schwarzchildradius
only if you consider light abstract, which I guess it kind of is. if you could "ride" light, of course, you wouldn't be moving through time.
