russ_watters
Mentor
- 23,829
- 11,305
"2500+" is a "performance rating" meaning it performs about the same as a P4 running at 2.5 ghz. Its a marketing thing since most people only look at the number and don't necessarily understand that that's not the only factor in determining performance. The 2500+ runs at 1.83ghz (variations of a % or 2 are normal).
Virtual memory is what your operating system uses on your hard drive when it runs out of physical memory (ram). Since you have 512MB, it is unlikely that you will ever use much virtual memory (windows always uses a little) so changing the size won't have much effect on your system - it won't be used.
64 bits (I mentioned it in another thread) refers to the size of the numbers or instructions that a computer can handle at one time. One of the main benefits initially is that it breaks the 4 GB memory barrier - 32 bit processing if you do the math (2^32) means you can only address up to 4GB of memory.
As for your freezing problem, hit ctl+alt+del once and click "task manager" then "processes" and it will tell you exactly what programs are using how much of your processor. You may be able to pinpoint (and disable) the one that is messing you up.
512-480=32MB. 32MB is the amount of your system ram being dedicated to your display adapter. Machines without a dedicated video card and its own ram have to steal system memory. Its not a real big deal except that it is considerably slower than dedicated video ram - if you ever get into 3d games, you'll want a stand-alone video card.
