Atlas of complex projective 3-space ##\mathbb{C}P^3##
  • Context: Graduate
  • Thread starter Thread starter kloptok
    Atlas Complex
The discussion focuses on constructing an atlas for complex projective 3-space, denoted as ##\mathbb{C}P^3##, utilizing inhomogeneous coordinates ##z_{i}/z_{j}##. The user successfully defines charts ##\mathcal{U}_j=\{z_j\ne 0\}## and seeks clarification on handling intersections of three charts, ##\mathcal{U}_i\cap \mathcal{U}_j\cap \mathcal{U}_k##. The conclusion is that one can indeed skip explicit consideration of these triple intersections, as the holomorphic transition functions between pairs of charts suffice to ensure the necessary conditions for holomorphicity across the intersections.
  • Understanding of complex projective spaces, specifically ##\mathbb{C}P^3##.
  • Familiarity with inhomogeneous coordinates and their applications in complex geometry.
  • Knowledge of holomorphic functions and transition functions between charts.
  • Basic concepts of manifold theory and atlas construction.
  • Research the properties of holomorphic transition functions in complex manifolds.
  • Study the implications of multiple chart intersections in manifold theory.
  • Explore examples of atlas constructions in higher-dimensional complex projective spaces.
  • Learn about the role of coordinate systems in defining complex structures on manifolds.
Mathematicians, particularly those specializing in complex geometry, differential geometry, and manifold theory, will benefit from this discussion. It is also relevant for graduate students and researchers working on complex projective spaces and atlas constructions.
kloptok
I'm constructing an atlas for complex projective 3-space ##\mathbb{C}P^3##. I use the construction with inhomogeneous coordinates ##z_{i}/z_{j}## and a chart is given by the points ##\mathcal{U}_j=\{z_j\ne 0\}##. At the intersections ##\mathcal{U}_i\cap \mathcal{U}_j## I should specify (holomorphic) transition functions between coordinates. So far I'm fine. Now my problem is, what do I do with the intersections between three charts, ## \mathcal{U}_i\cap \mathcal{U}_j\cap \mathcal{U}_k ## ? I have a feeling that I can skip them since ##\mathcal{U}_i\cap\mathcal{U}_j \cap \mathcal{U}_k=\mathcal{U}_i \cap(\mathcal{U}_j\cap \mathcal{U}_k) ## and I know what to do at each of the intersections ##\mathcal{U}_i\cap\mathcal{U}_j##. After all, isn't the point that at this intersection I can use either of the three coordinate systems and I only have to require holomorphic transitions between them?
Is this a correct way of thinking? It's probably a silly question but I can't get my head around this. All I can find when I search on the web is what to do at intersections between two charts, and nothing about multiple intersections.
You only need to check holomorphicity of the transition functions between each pair of charts since if you do that, then on the intersection of triplets, you're just restricting the domain of a map you already know is holomorphic.
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 28 ·
