Atom struture : opaque and Transparent
In summary: It explains why the concept of "molecule" no longer applies to most solids.In summary, the properties of a solid, such as transparency or opacity, are not determined by individual atoms but rather by the collective behavior of a large number of atoms interacting with each other. This is due to the presence of phonon modes, which can absorb photons at certain frequencies, making the solid opaque. However, if the photon has a higher energy than the available phonon modes, it will be re-emitted with a slight delay, giving the appearance of slowed light speed. It is important to understand that the behavior of solids is not the same as that of individual atoms, as highlighted in the FAQ post.
JPC
206
hey
what in an atoms struture tells us if the element is going to be transparent or opaque ?
what in an atoms structure tells us at what frequency photons will come out with after hiting the electrons ?
Please read the entry in our FAQ in the General Physics forum.
Zz.
ZapperZ [Physics Forums FAQ] said:
A solid has a network of ions and electrons fixed in a "lattice". Think of this as a network of balls connected to each other by springs. Because of this, they have what is known as "collective vibrational modes", often called phonons. These are quanta of lattice vibrations, similar to photons being the quanta of EM radiation. It is these vibrational modes that can absorb a photon. So when a photon encounters a solid, and it can interact with an available phonon mode (i.e. something similar to a resonance condition), this photon can be absorbed by the solid and then converted to heat (it is the energy of these vibrations or phonons that we commonly refer to as heat). The solid is then opaque to this particular photon (i.e. at that frequency). Now, unlike the atomic orbitals, the phonon spectrum can be broad and continuous over a large frequency range. That is why all materials have a "bandwidth" of transmission or absorption. The width here depends on how wide the phonon spectrum is.
On the other hand, if a photon has an energy beyond the phonon spectrum, then while it can still cause a disturbance of the lattice ions, the solid cannot sustain this vibration, because the phonon mode isn't available. This is similar to trying to oscillate something at a different frequency than the resonance frequency. So the lattice does not absorb this photon and it is re-emitted but with a very slight delay. This, naively, is the origin of the apparent slowdown of the light speed in the material. The emitted photon may encounter other lattice ions as it makes its way through the material and this accumulate the delay.
[color="#black"]message too short[/color]
Edit: Dammit Zz :tongue:
Well, you also missed the most important message in that FAQ. :)
The moral of the story there is that "individual atoms" no longer play a significant role in almost all of the obvious properties of a solid. That is something that needs to be highlighted. People continue to ask about atomic absorption when light passes through a solid, and that is just not correct. The optical behavior, at least in the visible range, is now governed by the collective behavior of the solid, not by the atomic level of the individual atoms.
If a solid behave the same way as individual atoms, there would be no need to have a field of study separate and different from atomic/molecular physics. Yet, we do Solid State/Condensed Matter physics.
Zz.
Moral of the story: the properties of a solid that we are familiar with have more to do with the "collective" behavior of a large number of atoms interacting with each other. In most cases, these do not reflect the properties of the individual, isolated atoms.
:redface: :blushing:
yeah i know its not the atom that makes the color, its the molecule
but i was just asking for the case of atoms to simplify things
Btw, thanks for your explanations
well yeah, i could have searched for a topic that would answer my questions , but there are so many of them, and I've only been here recently so
No, it's not the molecule either. In fact, in most solids, there's no such thing as a molecule. Please read the FAQ post more carefully - here's the link: https://www.physicsforums.com/showpost.php?p=899393&postcount=4
1. What is the difference between an opaque and transparent atom?
Opaque atoms are those that do not allow light to pass through them, while transparent atoms allow light to pass through.
2. How does the structure of an atom affect its transparency?
The structure of an atom determines how tightly its electrons are bound to the nucleus. In transparent atoms, the electrons are arranged in a way that allows light to pass through, while in opaque atoms, the electrons are tightly packed and do not allow light to pass through.
3. What properties of an atom make it opaque?
Atoms with a high atomic number, heavy nuclei, and tightly bound electrons tend to be opaque. This is because these atoms absorb and scatter light, preventing it from passing through.
4. Can an atom be both opaque and transparent?
Yes, an atom can exhibit both opaque and transparent properties. This depends on the material the atom is a part of and the wavelength of light being used.
5. How can we use the concept of opaque and transparent atoms in practical applications?
The properties of opaque and transparent atoms are utilized in various technologies such as solar panels, optical fibers, and LCD screens. By understanding how atoms interact with light, we can engineer materials to have desired levels of opacity and transparency for specific applications.
  • Quantum Physics
  • Materials and Chemical Engineering
  • Quantum Physics
  • Astronomy and Astrophysics
  • Atomic and Condensed Matter
  • Quantum Physics
  • Quantum Physics
