Atomic Electron Jump Wavelengths
The shortest wavelength of light that an atom can radiate due to electron shell transitions is determined by the energy levels of the atom, with Fermium (Z=100) exhibiting a Kβ energy of 136.08 keV, corresponding to a wavelength of approximately 9.11 picometers. The longest wavelength is not fixed but is limited by practical considerations, with transitions between high energy shells yielding lower energy emissions. Gamma rays, which have wavelengths less than 10 picometers, are produced from nuclear transitions rather than electronic transitions. The Lyman series provides a formula for the limit of wavelengths for hydrogenic atoms, specifically for single-electron ions, represented as λ = 1/(91.175Z²) in nanometers.
  • Understanding of atomic structure and electron shell configurations
  • Familiarity with photon energy and wavelength calculations
  • Knowledge of the Lyman series and its significance in atomic physics
  • Basic principles of gamma ray production and nuclear transitions
  • Study the Lyman series and its applications in atomic physics
  • Research the properties and applications of gamma rays in nuclear physics
  • Explore X-ray fluorescence (XRF) techniques and their relevance to electron transitions
  • Investigate the electron configurations and transition energies of heavy elements like Fermium
Students and professionals in physics, particularly those focused on atomic and nuclear physics, as well as researchers interested in electron transitions and photon emissions.
philip porhammer
TL;DR
what is the shortest wavelength of light that an atom can radiate by electrons jumping shells, and longest wave length
I don't know for sure, but I checked the available laser frequencies.
At this site: https://upload.wikimedia.org/wikipedia/commons/4/48/Commercial_laser_lines.svg
If shows Flourine (##F_2##) at 157nm and Methanol at 571,669um.
Of course, neither of those are "atoms".
So: Argon (Ar+) at 488 nm and Iodine at 1315um.
It also shows Nitrogen at 337.1nm, but I strongly suspect that is ##N_2##, not atomic Nitrogen.
Of course, there are going to be other emissions that cannot be lased for practical reasons.
what is the process that creates Gama rays? or, is a photon considered to have a wave length range?
I noticed that Helium has an emission line at 234nm.
Gamma rays are photons. They have wavelengths less than 10 picometers and are too powerful to be created chemically.
Suggest you read the wiki article: https://en.wikipedia.org/wiki/Gamma_ray
thanks, I have been wondering about this for awhile
Take the heaviest atom you can get, remove all electrons and add one in a high shell, let that electron go directly to the innermost shell. Neglecting relativistic effects you get up to ##Z^2 \cdot 13.6 eV## from these transitions where Z is the charge of the nucleus (=element number), in practice relativistic effects will change that energy. All these are considered x-rays based on their origin, while gamma rays come from transitions in the nucleus. Just a naming convention.
The longest wavelength: There is no such thing, just practical limits. Transitions between very high shells have very low associated energies.
Summary: what is the shortest wavelength of light that an atom can radiate by electrons jumping shells,
If by "light" you mean electromagnetic photons, and on Earth in the 21st century, then the simple answer is 136.08 kilo-electron-Volts (keV). As heavier elements are discovered, this value will rise accordingly as the Ka shell electron's binding energy rises.
That accounts for electrons jumping shells only.
Which is the characteristic Ka shell X-Ray energy of Fermium.
136.08 keV = 3.2904e+13 MHz (frequency) = 9.1111e-12 m (wavelength).
If you are referring to electrons that may leave the atom, then there is no upper limit.
If you want to explore induced shell jumping in an everyday metrology setting, study the practice of "XRF". This field also involves WHY electrons jump shells.
George Dowell
That is just the ##K\beta## energy of Fermium, not the highest possible transition energy. Remove all other electrons and consider a larger difference between shells, e.g. 10 -> 1, and you'll get a larger answer.
Yes thank you I typed Ka instead of Kb. Ka= 120.6 KeV and Kb= 130.08 KeV from a Fermium "atom". I interpreted the OP question as concerning a stable atom.
"Remove all other electrons and consider a larger difference between shells,"
Interesting, you've mentioned this before, I see allowed electronic transitions from the M and L shell to the K shell all the time. Please cite a direct Q-K or P-K electronic transition text (without the usual allowed cascade through the allowed transitions), so I can study that? Thank youGeorge Dowell
Fermium is not stable and the electron configuration that allows a Kbeta transition is not stable either (that's why there is an allowed transition). Why would you limit the consideration to neutral or singly-charged atoms?
I have never seen it measured for Fermium and there is probably not enough interest in it, but the Lyman series doesn't stop somewhere.
Thanks I understand now. I chose Fermium because I tried to respond correctly to the poster's actual question as I interpreted it. The answer required the heaviest "tested/known" element, one that could emit the highest frequency "light", and on my periodic table of Binding Energies, that's Fermium.
Perhaps you can cite a N-K, O-K, P-K or any other allowed and especially common and electronic transition.
If it's happening, it should be charted somewhere, if you don't have time perhaps another mentor will help with this.Thank you for your time.
George Dowell
and observable-in-a-high-school-lab electronic transition.
Adding conditions not present in the original question is seldom helpful.
Once it is cleared up, we need to talk about e-p annihilation, I'm still looking for basic peer reviewed information proving or disproving
That has nothing to do with this question.
t would be very simple to observe and test with tools such as the LHC. Unfortunately in the present time on the internet, most modern (that is up-to-date) technical books and papers are located in pay-for-view or subscription-only websites, making them unavailable to the ordinary student.
Not a single LHC paper is (exclusively) behind a paywall. Making false statements is not helping your credibility.
The OP's question has a simple answer - it's the limit of the Lyman series for hydrogenic atoms, and it's for single-electron ions:
\lambda = \frac{1}{91.175Z^2}
(units are nanometers)
What is an acceptable Z is arguable. Certainly fermium doesn't meet the rather odd high-school criterion, but bismuth certainly does. Oganesson (Z=118) certainly lives long enough to form a single-electron ion.
Thank you. I edited per your guidance, thank you. I want to do this right, it is very important to me and certainly am willing to understand and follow any and all rules.. George Dowell
  • · Replies 20 ·
