Ax+b=0 is one-variable linear equation
  • Context: High School
  • Thread starter Thread starter WannabeFeynman
    Linear Linear equation
8 replies · 4K views
WannabeFeynman
Hello
Am I right in saying:
ax+b=0 is one-variable linear equation
ax+by+c=0 is two-variable linear equation
ax^2+bx+c=0 is one-variable quadratic equation
ax^2+bx+c=y is two-variable quadratic equation
Every linear or quadratic equation in one or two variables can be represented in those ways.
How come graph of ax+by+c=0 is point of solution set {(x,y) | ax+by+c=0}? Why not (y,x)? Since we can rearrange it as x=(y=b)/m, can we pick the y value first and then find the x value?
I know graph of x=a and y=a is vertical and horizontal lines respectively because x or y will always be constant no matter what y or x is respectively. But how would we represent the solution sets? For x=a, would it be {(x,y) | x+0y=a}?
Thanks.
Mathematics news on Phys.org
WannabeFeynman said:
Hello
Sure.
I would say the general two-variable quadratic equation has the form
[tex]ax^2 + by^2 + cxy + dx + ey + f = 0[/tex]
It doesn't matter much. You might as well choose
[tex]\{(y,x)~\vert~ax+ by + c = 0\}[/tex]
It might not be the same set, but it will be an equivalent situation you're dealing with. Geometrically, this corresponds to just swapping X-axis and Y-axis.
Usually, we will of course use
[tex]\{(x,y)~\vert~ax + by + c = 0\}[/tex]
but that's a convention.
Yes, that will be one possible way of writing the solution set. Another one is
[tex]\{(x,y)\in \mathbb{R}^2~\vert~ x =a\}[/tex]
or
[tex]\{(a,y)\in \mathbb{R}^2~\vert~y\in \mathbb{R}^2\}[/tex]
Thanks a lot. That cleared my doubts.
graph of f(x) is graph of solution set {(x,f(x)) | f(x)=x+a}
Can I right it as x=f(x)-a too?
I would say the graph of a function ##f:\mathbb{R}\rightarrow\mathbb{R}## is
[tex]\{(x,f(x))\in \mathbb{R}^2~\vert~x\in \mathbb{R}\}[/tex]
or perhaps
[tex]\{(x,y)\in \mathbb{R}^2~\vert~y=f(x)\}[/tex]
In the case that ##f(x) = x+a## for all ##x##, then this becomes
[tex]\{(x,x+a)\in \mathbb{R}^2~\vert~x\in \mathbb{R}\}[/tex]
or
[tex]\{(x,y)\in \mathbb{R}^2~\vert~y=x+a\}[/tex]
and you can write this of course as
[tex]\{(x,y)\in \mathbb{R}^2~\vert~x=y-a\}[/tex]
So
[tex]{(x,f(x)) | f(x)=x+a}[/tex]
is wrong then?
Can't get { and } to show...
So
is wrong then?
If your ##f## is defined by ##f(x) = x+a##, then that just says
[tex]\{(x,f(x))~\vert~x+a=x+a\}[/tex]
which simplifies to
[tex]\{(x,f(x))~\vert~0=0\}[/tex]
So yes, it's not really right.
The how come
[tex](x,y) | y=x+a [\tex]<br /> <br /> is correct?[/tex]
Then how come
[tex](x,y) | y=x+a[/tex]
is correct?
