Axial Piston Pumps Equation Help
1 reply · 4K views
Davieslad
Right, I am in the process of designing an axial piston pump.
I have obtained the following formula from a textbook for power output. unfortunately i don't know what units the formula requires, is anyone able to confirm what they are? Also, if anyone knows of a good resource for pump design please let me know!
right
P=2rANtan@(p2-p1)n
where
P=power
r=radius of centre of piston from axis
A=area of piston
N=number of pistons
@=swashplate angle
p2 and p1 = pressure differential
n=either rpm or revs per second - i don't know
I need the formula to be in metric form - basically, if i use
P=Watts
r=metres
A=metres^2
p=pascals
n=rpm/rps
Will the formula be correct?
Many Thanks
Ed
Have you tried deriving it for yourself? This is always a good start.
At the very least, you should be able to check the units.
